Old 28-05-06, 11:58 AM   #11
Filipe M.
IIRC, USB2.0 sends data in bursts, Firewire/IEEE1394 keeps a constant stream. That's why you can send DV uncompressed video streams over Firewire (like from DV Camcorders), but can't do it over USB2.0.
Old 28-05-06, 12:05 PM   #12
Carsick
Another factor that makes firewire quicker is the fact that you have a very small number of ports, and if I'm remembering the correct specs, each one pretty much operates independently to the others. USB ports (1.1 and 2) all operate over a single bus, so overall speeds might be fantastic, but like a network connection, it's all spread out between the stuff going on and I believe that's the reason it works in bursts.
On the other hand, I only just woke up from last night and my head still feels a teensy bit fuzzy, so I may be talking cod****.
New Hard Drive - Noise? 600+ Idle Banter 3 30-03-09 06:17 PM
Which External Hard Drive? Miss Alpinestarhero Idle Banter 48 10-02-09 08:12 PM
New hard drive required Stu Idle Banter 23 09-12-06 02:37 PM
IT help - hard drive question will Idle Banter 7 25-05-06 06:42 PM
pc hard drive question will Idle Banter 6 15-05-06 02:38 PM
