#11 |
I don't think it makes much difference hot or cold as long as the bike is level and the oil has had a minute to drain down to the sump.What is important is that you do it regularly.
#12 | |
having just filled , assumming that was time he meant fiver or so minutes should be sufficient time to let the oil drain down to the sump before checking it. Cheers Ben |
#13 | ||
#14 | |||
![]() ![]() Cheers Ben |
#15 |
In the sv manual on changing oil and filter you shuold pour in about 2.3 litre start the engine for 2-3 mins and then leave for 5 then check oil level and top up if need to, or if you are checking it before a ride it should be done when engine is cold and bike is level.
#16 |
Are you using fully synthetic oil?
That does burn off quicker than the usual semi-synth, especially if you have a little engine wear. |
World War 2, how close did we really come to loosing? | Daimo | Idle Banter | 113 | 19-01-08 10:03 PM |
loosing power at high revs | riktherider | SV Talk, Tuning & Tweaking | 2 | 23-08-07 11:22 AM |
Loosing tyre pressure on almost new tyres... | SpankyHam | Bikes - Talk & Issues | 23 | 25-07-06 06:50 PM |
loosing pressure - updated - shard of metal in tyre ! | Mr Toad | SV Talk, Tuning & Tweaking | 22 | 15-07-06 10:41 AM |
