Old 21-07-06, 08:50 AM   #11
Viney
Originally Posted by jambo
Bugger
Have you tried just dumping 3.5L of fresh oil in it to see if it runs?
If so might be worth running for a few minutes at various loads, then dumping that oil & filter out and re-filling. For the firt run you can use any old cheap mineral oil so for £15-£20 I'd give it a wirl, it may not last foever, but at least you don't then have to pick up the first overpriced lump that turns up?
2.6L
Old 21-07-06, 08:57 AM   #12
Daimo
I did think of re-filling with oil and turning on. Shot down the road last night (shop shuts at 8 on thurs), picked some up, got home, then decided against it.
(went out in car, not bike).
Every search is coming to a dead end as well at the moment
Old 21-07-06, 09:01 AM   #13
It's probably ****ed though, new oil doesn't help once you've damaged a shell. BUT! Might not be that. Sounds like it but check your cam timing first, it's possible it's jumped time- failed cam chain tensioner or chain- and that your noise there is valves clashing. I don't think it'll be that, but it's well worth checking IMO. If it is, it's all repairable (PM me if it is, I've got valves, tensioners etc in the heap somewhere)
Good luck! There's a fair amount of scrap value in an SV engine if you can be bothered to break it down, for what it's worth- casings, barrels and heads, cams, clutch and tensioners all seem to get decent prices, I've bought whole broken engines for £40 and recouped the whole cost inc postage just from the cams and heads...
Old 21-07-06, 09:15 AM   #14
timwilky
timwilky's Avatar
Default Re: Think i've seized it :-(
Originally Posted by Daimo
Coming home tonight, bit lost power and cut out.
Started again and sounded like someone smashing metal together.
Limped home, pulled the sump plug out to find 2-3 small bits of metal. Looks like the oils run low without warning and the heats got to it. I only checked it a few weeks ago..
So, how much does a 2nd hand K2 SV 650 motor go for these days
Anyone else got any other ideas? I really think its buggered though
Let this be a lesson to you, There is a low oil indicator on the crankcase, use it.
I check my oil, like my tyre pressure before I ever wheel the bike out the garage. to go a "few weeks" between checks is simply asking for trouble
Not Grumpy, opinionated.
Old 21-07-06, 09:36 AM   #15
21QUEST
21QUEST's Avatar
True. The oil check is a 'must do' for me even if I'm running late.
Ben
Nemo me impune lacessit.
Old 21-07-06, 10:03 AM   #16
Daimo
People learn by their mistakes....
Old 21-07-06, 10:06 AM   #17
Daimo
Cheers, bear that all in mind.
Thats all good to know also. But rather than stripping the original, if i can find another lump (unknown internal damage till its stripped, which I will do as i'd like to as a mini project... Hmmmmm go-kart + SV engine??). Or maybe turn the old engine into a table like they did on top gear a few yers back.
ITs jsut a serious bummer and like all things sods law related, had to come at a time when i could really do without. Still neededing to replace my jacket and boots yet for the winter too
Old 21-07-06, 12:31 PM   #18
TC3
Do not screw things up for yourself even more by driving an untaxed car....assuming it was your car you used to go get the oil
Old 21-07-06, 01:03 PM   #19
If it's top end, you could probably fix it in a long evening y'see, worth checking. But it's a wee bit of clutching at straws.
I've got two blown up engines in the garage still... Did have 3 but I skipped most of it after selling all the good bits One of these days I'm going to figure out which one's most salvagable and set about putting my spare crank in it. Because it's there Taking the other one to bits was pretty good, learned a lot.
Old 21-07-06, 01:09 PM   #20
Daimo
In todays big brother style government society, wouldn't dare, esp not with all them cameras about.
Nahh, Corsa is off the road (both). The VXR is the daily drive.
NWind - Yeah, thats what im hoping to do, learn a lot more from tinkering...
Gonna try to get the engine out this weekend. Fun......
I've sourced an engine through SVspares (BIG thanks Flaming Squirrel) that is about £320 inc VAT and only £35 to deliver to kent as well. Sound like a good buy?
Just about to check mileage etc...
The throttle is all seized up MrG650 SV Talk, Tuning & Tweaking 25 14-06-10 04:02 PM
How can I tell if my brakes are seized? arcdef Bikes - Talk & Issues 16 17-11-08 02:31 PM
Seized Screw TheShadow Bikes - Talk & Issues 7 03-07-08 12:17 PM
brakes seized......... a bit hovis Bikes - Talk & Issues 7 25-01-08 08:05 AM
seized bolt + more hovis Bikes - Talk & Issues 26 07-01-08 11:06 PM
