Old 22-07-06, 08:54 PM   #11
NedSVS
Don't really agree with Blue_SV650S's comment
If you are putting new cams in you will HAVE to do the shims dude (I presume that is what you mean by 'buckets'?), the clearances will be all over the shot!!
When I did the K3 inlets and moved the original inlets to the exhaust side there was no measurable difference before and after on valve clearance. The cams are ground to such fine tolerances that this is not an issue at all. Also you are measuring the clearance at a point on the cam that gets no wear (as it doesn't run on the bucket because of the clearance). If the clearances are good before they will be good after. Just take special care to keep the buckets and shims in the original places, i.e. don't mix them up
Old 22-07-06, 09:19 PM   #12
You won't be nmoving the shims and buckets at all if the clearances are OK, no risk at all of them getting mixed up. There's a chance that it will need new shims, don't rule it out, but you're right that it might not be neccesary.
Old 23-07-06, 01:52 PM   #13
Robw#70
This is why the clearences are measured at this point as it is a constant, Its the valve seats that wear/bed in thus effecting clearences
And if swopping cams then why the need to remove the buckets at all
Pointy Cams ? LEXINGTONONE SV Talk, Tuning & Tweaking 11 06-06-08 10:02 AM
Pointy (or maybe curvy) cams Spoon Stuff Wanted 0 13-04-08 01:03 PM
Pointy (>=03 Injected SV) Cams - or complete engine Blue_SV650S Stuff Wanted 2 04-03-07 09:12 PM
Pointy Cams G - renamed Stuff Wanted 4 16-07-06 11:50 AM
SV 650 CAMS wanted K3-K6 injector pointy cams wanted alien19779 Stuff Wanted 3 09-03-06 07:01 PM
