Old 24-07-06, 08:13 PM   #11
chunkytfg
Originally Posted by kwak zzr
whats best mr northwind?
a lazer track system is the best but i'd doubt none of us have one of them lying around so a good way of doing it is to run a straight edge down the sprocket
Old 24-07-06, 08:17 PM   #12
Biker Biggles
Biker Biggles's Avatar
On my old Rickman the chain is adjusted by shims at the swingarm pivot.As long as you put the same shim in each side the wheel will be straight,and the bike comes with a set of shims in the toolkit.It's no more tricky to adjust than normal,so I wonder why modern bike design has not got very far when it comes to chains.
Old 24-07-06, 09:05 PM   #13
Have a swingarm with markings that are accurate, like me I like the swingarm axle-reat axle method myself.
Old 24-07-06, 10:21 PM   #14
chazzyb
I run an old AJS. The rear wheel spindle has snail cams either end keyed onto it which bear on 'followers' on the end of the swinging arm. Turn the adjuster nut on one side with an adjustable spanner and both sides move the same amount. Brilliant! They went for a cheaper method in 1957 - a bolt and lock nut adjuster each side.
Your old Rickman - a dirt bike, later jap-engined road bike or something really lovely like an Interceptor?
Old 24-07-06, 11:32 PM   #15
$tevo
http://www.ukmot.com/bike/2-5.asp
Old 25-07-06, 12:07 AM   #16
Originally Posted by northwind
The string to the front wheel method's incredibly easy to foul up, to be honest.
Not if you take the slightest care, it's a good method - but you do need to understand what it is you're trying to do.
Old 25-07-06, 12:26 AM   #17
Mmm.. Disagree there. I think there's better ways.
Old 25-07-06, 07:54 AM   #18
petevtwin650
My local Co-op is selling a laser sighting tool for under a fiver, wondering if it's worth buying and seeing if it can be made to do the job of the £40 laser tool sold for bikes.
I used to take out my wheel replace the spindle and measure to the rear end of the swingarm on the theory that the swingarm will be the same length both sides. Was I right?
Old 25-07-06, 08:22 AM   #19
Jester666
Nothing there about loud pipes!! Does that mean they are ok?
Old 25-07-06, 08:25 AM   #20
adjusted it **** on now guys cheers, kwak.
Rear Wheel DarrenSV650S Stuff Wanted 0 23-03-09 09:36 PM
rear wheel antony SV Talk, Tuning & Tweaking 5 26-05-08 01:22 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
cbr rear wheel yorkie_chris SV Talk, Tuning & Tweaking 33 20-02-08 11:09 PM
Rear wheel on K4 and K2 opsman Bikes - Talk & Issues 1 27-12-06 01:02 PM
