Old 28-07-06, 02:37 PM   #11
Originally Posted by Filipe M.
Originally Posted by kwak zzr
i run 2 sicks of 512ddr ram if the pc is showing its all there in its memory check it cant be that can it?
Is it running the full or the quick check? If you know how to do it, turn the full check on in the bios.
quick check dont know how to enable the full check?
Old 28-07-06, 02:40 PM   #12
philipMac
It might also be the power supply on the way out.
This very difficult to diagnose. Eliminate the other components, memory and hard drive, and then consider the power supply.
In the mean time mate, I would buy myself a little external hard drive, and back my stuff up onto this. You will always have this extra drive for your peace of mind.
Old 28-07-06, 02:41 PM   #13
computer has been on now for about an hour and its fine, its only when i turn the bloody thing off and it cools down and i try to boot again.
Old 28-07-06, 02:42 PM   #14
i was actully thinking hdd boot up fault.
Old 28-07-06, 02:44 PM   #15
$tevo
My old 'puter did that until I put a new sound card in it! Go figure...
Old 28-07-06, 02:51 PM   #16
OB sound??
Old 28-07-06, 03:03 PM   #17
$tevo
Nah, took dusty old card out and put new one in - dunno why it fixed it
Old 28-07-06, 03:21 PM   #18
Abyss
this sounds like one of those problems that is normally solved by formatting and starting from scratch but as you have already done that it really falls onto hardware.
Memory is normally the cause of crappy issues like this but there isnt always an easy way to test without having any space to swap out and try.
first you can try running something like http://www.memtest86.com/ to see if that comes up with anything, if not try ripping out one of the sticks (so your downt to 512) and see if the problem re-arises. If it does rip out the other stick and put the 1st one back in and repeat. If it is a ram problem its not likly to be both sticks so this may help.
Ive had a problem like this be caused by a crappy PSU aswell (cheap jobby that was about a year old)
Old 28-07-06, 03:24 PM   #19
cheers i try that.
Old 28-07-06, 03:37 PM   #20
philipMac
cheers i try that.
Sniff sniff... still smells like a burnt power supply to me...
Computer help please Stu Idle Banter 7 09-11-08 07:28 PM
computer problem custard Idle Banter 19 06-09-08 12:50 PM
More computer help... JediGoat Idle Banter 1 17-09-06 01:24 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
