#11 |
I was given advice to use the rear brake on here on a bit of road i use...
It made my cornering much quicker, more controlled, and the bike was easier to get into the corners... I use my rear brake loads, mainly for dropping off that little bit more speed if im still going in to hot as the bikes tipped over... Also use it at slow speeds in the city, if you just hit the fronts in town, u'll loose it as the roads are so greasy. TSM, cheers for that dude, more options now ![]() |
#12 | |
![]() Whatever works for you, the Rear brake on the Kwak is a Single piston sliding caliper, but works well enough. I just use almost all front brake ![]()
#13 |
I find I barely use the brakes at all on the SV. I only use the rear brake with a pillion and on my own I mainly use 1 finger on the front brake and let the engine do the braking.
#14 | |
But... My accident happened because i paniced (car cat accross lanes in rush hour without indication or looking) and hit the fronts too hard. I really think i've i'd have gone on the rears as well I wouldn't have gone down. But we learn as we grow ![]() Just meant i use my rear brake, but where possible, i try not to at all, and judge the distance (I.e traffic lights) and just come off throttle and let the great engine braking do the job... Saves my pads ![]() |
#15 | |
#16 | |
#17 |
Yup.
#18 | |
Using the rear with the front doesn't really slow you down much quicker, but it can help stabilise the bike and reduce the amount of dive. I generally use the rear only when in 1st and about to stop, at lights or a junction, for example. If I need to brake hard, I will use the rear, but a couple times I have locked the back wheel by adding a little too much. |
#19 | |
![]() ![]() FWIW(GT of SFA :P ) , I think the rear brake causes more problem that most peeps realise more so in the wet. I probably use my rear brake less than five times a day no matter where. It's good to be able to trust and if I may say , learn to use your fronts effectively. Cheers Ben |
#20 | |
The rear brake on my CBR is useful for illuminating the brake light and no more. |
Replacement Brake Lever - fairly standard fits? | schofs | Bikes - Talk & Issues | 7 | 09-11-08 10:52 AM |
Cleaning all around the rear wheel / swingarm / rear brake caliper | Camel | SV Talk, Tuning & Tweaking | 12 | 28-04-08 02:00 PM |
Brake light not working when rear brake is used.. | StreetHawk | SV Talk, Tuning & Tweaking | 10 | 16-04-07 03:40 AM |
04 svs what rear shock fits? | Captain Nemo | SV Talk, Tuning & Tweaking | 2 | 12-05-05 04:11 PM |
which gsxr rear shock fits sv650 sk3? | Torn | SV Talk, Tuning & Tweaking | 1 | 14-03-05 04:45 PM |
