#11 | |
I guess that you'd still have to pull the clutch lever in too to bypass the inhibit and you'd get quite a hairy launch!! |
#12 |
just remeber to keep your cables well lubed and it won't happen again. IMHO it's often one of the more overlooked pieces of maintenance and makes a huge differrence.
#13 |
When you replace the old cable, tie the new one to the old with Gaffa tape or similar and then pull it through. That way all the cable routing is correct, and you don't have to fiddle about trying to get the new one to sit right
#14 | |
#15 |
To clarify:
Tie the new cable housing to the old cable housing. You do not buy just the bit of wire in the middle but the whole part including the black casing and fittings. ![]()
#16 | |
#17 |
Slightly off topic but how do you lube the clutch cable?
#18 |
You can try all sorts of messy routes dripping oil in from the top. I use a Hydraulic cable oiler which I bought for about £15. I put a mix of engine oil and LM grease in it and it puhes this mix through the housing from one end to the other. Messy but effective.
#19 | |
spray grease in a can and a long spray pole thingy... discconnet from both ends and spray then wiggle... ![]() do this for all new cables too! |
#20 | ||
Clutch been snapped off | H | Ancillaries | 8 | 11-03-07 10:58 AM |
Blown ingnition fuse plus snapped seat lock cable | Longshotmojo | SV Talk, Tuning & Tweaking | 1 | 09-03-06 11:05 PM |
Clutch Cable Snapped: | MrMessy | SV Talk, Tuning & Tweaking | 2 | 16-01-06 09:18 AM |
Clutch cable snapped on a 99 plate. | Scoobs | SV Talk, Tuning & Tweaking | 13 | 13-05-05 10:28 AM |
