Old 05-09-06, 05:49 PM   #11
Robw#70
The racetech springs are very consistant and cope with mileage, I have found other(cheaper) springs shorten after about 8000miles (ie full service time) needing more preload for the same sag.
If you want good allround road/track performance then Hyperpro springs IMHO are best, not too harsh at lower speeds and stiff enough when needed, however they dont work as well with emulators (being progressive).
15wt oil will give about the right amount of rebound with just springs
Old 05-09-06, 06:20 PM   #12
Blue_SV650S
PDQ (that’s who you work for right?) who I got my 80 racetech's from do Hyperpro springs:-
<snip>
Hyperpro Front Fork Kits
The Hyperpro front fork kits feature superior high alloyed chrome steel springs - specially polished for minimum friction, which carry a lifetime warranty against breaking. The springs are manufactured to DIN-2095 Class 1 and are specially designed and tested to give maximum performance. They come complete with fork oil, fork seal lubricant, stickers, instruction sheet and set up tips.
Hyperpro Constant Rising Rate (progressive) Fork Kits = £97.00 inc VAT
<unsnip>
so that’s £97 including the forks oil ... is that 15w oil like you recommend or do I get to choose on the day???
Old 05-09-06, 06:58 PM   #13
Robw#70
I used to work for them, the oil comes in the 'kit' I think its 15wt, having been on the course with the Hyperpro designer I know how much research goes in to their kits---so would fit whatever came in the box.
The distributer changed for Hyperpro, but PDQ can still get them, just wont be in stock but should only be a couple of days to get in.
But I think they're a bit dearer now £114 springs to mind, but dont quote me
Old 06-09-06, 08:13 PM   #14
bikenut34
Default BLUES SUSPENDERS
HI
I fitted progresive fork springs in my K1 SV the cost of the srpindgs £54.00 labour
ZERO and thet make a hell of a differance use 15wt oil and be presise with the oil.
they have a web site but i cannot remember what it is put that down to old age sorry
Old 06-09-06, 08:19 PM   #15
Blue_SV650S
Cheers guys
£114 is sounding a darn site closer to £200 than £97 ... it'd almost be worth throwing the extra at it to do the job properly!?!
bikenut34 - £54 ... that sounds more like me what make are they?? I can look them up myself.
Old 07-09-06, 01:51 PM   #16
CHICKENSTRIPS
Default Ohlins
I fitted Ohlins springs a year ago, no cutting of spacer needed, straight drop in. If you like back roads I would recommend not using 15 WT oil, I had 15 WT in mine and the front end got a bit lively on uneven surfaces, 12.5 WT is a pretty good compromise. Just had a ride on my mates stock SV the other day and the difference between his suspension and mine (Ohlins front spring and gixxer rear shock) was night and day when pushing on a bit. At the end of the day any reputable spring set up will be better than standard.
Old 07-09-06, 07:38 PM   #17
bikenut34
Default blues fromt end
Hi bluey
the springs are from a company called progressive suspension USA and i got them through MandP ,the web address is www.progressivesuspension.com
e mail info@progressivesuspension.com
hope you find what you are looking for
Old 07-09-06, 09:58 PM   #18
Blue_SV650S
Ok cheers for the info guys! Gonna ring around and get some prices
Old 08-09-06, 08:19 AM   #19
petevtwin650
Recently fitted the emulators, .90kg racetech springs and 20wt oil. The price complete with 2 litres of oil, although I only used 1, and delivery was £206.21 delivered. That was from PDQ. Came through in a couple of days. Good service.
Old 08-09-06, 11:16 AM   #20
I paid less for my front end swap
Do emulators work with progressive springs? stuballs SV Talk, Tuning & Tweaking 4 01-01-09 08:05 PM
emulators again antony SV Talk, Tuning & Tweaking 67 24-02-07 07:41 PM
New springs and emulators.Couple of tips. petevtwin650 SV Talk, Tuning & Tweaking 0 23-07-06 01:04 PM
Emulators RingDing SV Talk, Tuning & Tweaking 27 07-07-06 07:49 PM
Racetech Emulators and springs pjsv650s Ancillaries 3 30-07-05 12:58 AM
