Old 13-09-06, 07:23 PM   #11
TSM
The Sick Man
TSM's Avatar
Im a semi-tart and decided to go with a GSXR Radial MC, much nicer.
Old 14-09-06, 08:48 AM   #12
Jase22
Cheers guys, that's 4 options that I could try then.
Will keep the mince pies peeled and see what comes up. Honda or Yamaha stuff is generally made better so would be an improvement over the Suzuki budget bits.
Old 14-09-06, 08:49 AM   #13
TSM
The Sick Man
TSM's Avatar
The items are still usaly made by the same company Nissin (Honda/Suzuki) & Brembo (Yamaha) etc..
Old 14-09-06, 09:50 AM   #14
Blue_SV650S
Or you could do what I did …
I felt part of the problem was that the ‘span’ just wasn’t far enough out and that by the time I was getting pressure on the leaver (i.e. all the slack was taken up in the brakes) that it was already too near my reamining fingers (on the bar) to get a decent pull.
So what did I do?? I cut a bit of alli out and slotted it in where the adjuster bit of the leaver meets the arm (ohhh that is poor explanation!! ) If you push the leaver forward, a gap appears where the adjuster is, shove a bit of metal in there. Its not as much of a bodge as it sounds, as it always has pressure on it from the span spring it isn’t going to go anywhere.
It gave me that much more ‘feel’ and power. I have done the same thing on both my road and trackbike and personally I now think they are ‘acceptable’ and would recommend it.
Give it a try, it is free and easy, it might be all you need too.
Old 14-09-06, 10:36 AM   #15
Ter
FYI,
4XV is a 98/99 R1.
Old 14-09-06, 01:02 PM   #16
Well... Not quite. The Yam Brembos are actually made by Yamaha themselves (or outsourced to another japanese company, I'm not sure)- they're under licence from Brembo.
Old 30-10-06, 11:06 PM   #17
r4ce_e3nd
not to start a new topic:
is een CBR1000 K5 MC a good option? or has it a too big bore?
I am looking for a better master cylinder to enhance the feeling and braking power...
and what about the brake light? will the connection fit directly onto the sensor or not?
Old 30-10-06, 11:14 PM   #18
Pretty much any brake light will work one way or another, at the end of the day it's just a switch. You might need to solder it in, or it might just work. The R1 switch doesn't fit the SV connector, but the SV switch fits to the m/c, for instance.
No such thing as too big bore, IMO, it's purely a matter of taste. Maybe you want all your braking to happen in 1cm of travel, or maybe you're like me and want to use loads.
Old 30-10-06, 11:27 PM   #19
r4ce_e3nd
I prefere a solid brakelever...
sow, this MC has a bigger bore than stock SV but not way too big. do you know how much?
will this MC make a big difference to the stock one or is it just a little bit better..
Old 30-10-06, 11:29 PM   #20
Don't know really... I bought a machined-from-billet-by-virgins Brembo a while back so I care not for your inferior "Nissin" garbage
Wanted - master cylinder pipey Stuff Wanted 0 29-05-08 09:49 PM
GSX-R master cylinder. phil24_7 SV Talk, Tuning & Tweaking 14 09-01-08 02:04 PM
Master Cylinder phil24_7 Bikes - Talk & Issues 1 28-07-07 11:12 PM
R1/R6 Front master Cylinder jonnygman SV Talk, Tuning & Tweaking 6 29-04-07 01:10 PM
front master cylinder upgrade andygib SV Talk, Tuning & Tweaking 4 16-08-06 07:49 PM
