Old 07-11-06, 07:45 PM   #11
dieter
I made a clutch convertion to hydraulic clutch from TL1000 -> read there
Here in germany someone made a convertion for only a few pence -> look there i hope the photos are talking for themthelves klick for bigger photos!
Greets Dieter
Old 07-11-06, 09:57 PM   #12
Changing the lever or lever and mount does only one thing - it makes your wallet lighter.
If the lever is too far from the bar for you, or indeed in this circumstance Annie, slacken the cable adjuster a bit, thus leaving the lever a dab closer to the 'bar, which is exactly the same as an adjustable lever does, on each closer setting it pulls the cable a little less overall.
As long as the clutch separates sufficiently and doesn't drag, the adjustment is OK. In practice, all else being in good condition, you can back the adjustment off to suit even the littlest hands without problems.
stubby brake and clutch levers? stuballs SV Talk, Tuning & Tweaking 19 18-01-09 01:27 PM
2 finger brake and clutch levers bronze svrider SV Talk, Tuning & Tweaking 7 30-07-08 10:56 PM
Clutch levers? rob13 Bikes - Talk & Issues 6 01-11-07 06:30 PM
Brake/Clutch Levers Tris SV Talk, Tuning & Tweaking 1 18-06-07 12:58 PM
Clutch lever for small hands lawsey SV Talk, Tuning & Tweaking 9 18-05-05 11:27 AM
