#11 | ||||
![]() thats an absolute beauty ![]() *note to self, next time i can't sleep.....* |
#12 |
I must be selective in my geekery, as that other thread bored the tits off me too
#13 |
I guess the marketing peeps prey on the ignorance of the masses (including me). Words like "machined" and "billet" sound impressive, and the product is usually shiny, so people go "ooh!"
I for one won't be buying any load bearing "billet" components... does a tax disc holder count? Thanks for the thread guys ![]() |
#14 | |
http://en.wikipedia.org/wiki/billet says:
#15 |
Generally I see things described as machined from billet aluminium, which would still mean something (not much, admittedly)
#16 | ||
#17 |
I thought a billet was what you slept in in the forces!!!
#18 |
I bought a billet Brembo m/c a while back. Before that I had a forged one. It was just described as "forged", which tells you no more than billet- should it say "cold forged from XXX alloy"? The SV has a cast frame- is it relevant that it's sand-cast not rubber cast?
#19 | |
![]() ![]() ![]() Cheers Ben |
#20 |
as you say
forgings are the strongest as the grain follows the profile machined from billet cuts trough the grain most components that are machined from billet are to replace components that have been cast, either sand casting or die casting normally, casting is a cheap way of mass producing components to a fairly tight tolerance, but still need slight machining, drilled and tapped holes, mating faces etc, due to the casting process, the material is very brittle, it shatters on impact, billet material is softer, and will disform on impact, eg, if you drop the bike, you will probably hole the engine casings, with billet casings you have a better chance of just denting them, allthough they can still break, I'll go for machined from billet, better than a casting, not as expensive as a forging |
SV personalised billet ware | sibbo | Pennine Massive | 0 | 28-08-08 11:34 AM |
SV personalised billet ware | sibbo | Pennine Massive | 0 | 28-08-08 11:31 AM |
More Bling! Billet Top Yoke. | Lissa | SV Talk, Tuning & Tweaking | 12 | 11-08-07 05:53 PM |
Billet Aluminium Brake Fluid Cap | independentphoto | Photos | 22 | 08-09-05 11:21 PM |
