Old 09-02-07, 08:11 PM   #11
Lissa
Just Ballast
Lissa's Avatar
Paint job looks good Jussi
I appreciate that you haven't had time to fit the kit yet, but does it look like it will be easy to do so, and of good quality?
Old 09-02-07, 11:16 PM   #12
Jussi
Well the meter itself is small so maybe i but it on the right side of main gauges - It comes with a velcro strap. Koso also has antoher model with back light and external power connection, but i have not seen it yet. The one i have is battery operated, however, it uses the same adapters so no problem if i change the meter unit itself. I also purchased "T" tube to put to the left side radiator hose. To measure the temp from there. It is not perfect, but i wanted to have the oem warning light functional. The tube is 26mm and Koso makes these things and it was not even expensive.
So a couple of hose clamps and i can "shut down" the radiator hose and install the "T" piece, wiring and final assembly place for the meter there we go. I reckon it is not difficult and time consuming . if one has these clamp so that you do not have to drain the cooling liquid.
Curvy Temp Gauge carsounds_dan SV Talk, Tuning & Tweaking 5 01-05-08 08:29 AM
oil pressure Gauge Apophes Pennine Massive 2 11-01-08 01:11 AM
Oil temp gauge Mike2165 Bikes - Talk & Issues 7 12-09-07 08:04 PM
temp gauge on a curvey? jim@55 Bikes - Talk & Issues 14 02-05-06 07:33 PM
Fuel Gauge SPeeeeDY SV Talk, Tuning & Tweaking 5 29-01-05 02:03 PM
