#11 | |
#12 | |
#13 |
Can you change to dot 5.1 without flushing the system then? Cos if so, as far as I can gather there's no reason not to change to it, bar what - £3 or £4 extra cost?
Brake fade seems a pretty common problem amongst most bikes on track, so must be worth trying something with a higher boiling point? |
#14 |
whats the easiest way to bleed them then? Im gonna get a 2 line setup but want it to be hassle free
#15 |
Big syringe, squirt in from the bottom... Definatley my favourite method. I'm not vey good at bleeding brakes
#16 |
Hi All.
One important point has not been raised here, unless I missed it. As time goes on and the fluid has absorbed moisture, the boiling point of the fluid is reduced so you may notice brake fade start to creep in. Not good on a bike. Tim. |
#17 |
On the subject of brake lines, I know you're supposed to use new brake fluid out of a new bottle for bleeding brakes each time. However, I was wondering for how long after it has been open is acceptable to use it?
Basically I've bled my brakes 2 days ago, couldn't get them right. Left it overnight in case they were airated. I've now come back and am ready to give it another go. I take it the new (opened 2 days ago) fluid, which has been kept in the bottle with the lid on since, will still be fine? How long could you leave it, a week? More? Just curious... |
#18 |
I'm guessing here...
If you leave the fluid too long, the water in the air will condense and be absorbed by the fluid itself. This could happen from the first time you open the bottle, so best to use as much as you can, and always replace the lid after use. Maybe it's capable of absorbing water straight out of the air at its surface - no condensation required. I guess it could depend on how much is left in the bottle... a little trickle, I'd buy a new bottle. Enough for a top-up, then possibly okay. NB: this is not official advice - just my thoughts.
SV650 K3 - Gone. Now a member of the SV650.org Kawasaki brigade! |
#19 | |
radiator fluid | Svkid | SV Talk, Tuning & Tweaking | 2 | 28-02-08 06:22 PM |
Brake Fluid top up | Nekkid | SV Talk, Tuning & Tweaking | 7 | 30-03-07 11:57 AM |
Change in weather= Change in diet | Dicky Ticker | Idle Banter | 5 | 15-08-06 06:51 PM |
Need a quick way to change cooling fluid | Dennis | SV Talk, Tuning & Tweaking | 4 | 23-05-06 01:23 PM |
brake pad change - top up fluid? | branny | SV Talk, Tuning & Tweaking | 44 | 20-04-06 10:12 PM |
