Old 15-11-06, 01:32 PM   #11
Viney
Never had a problem getting relayed home. I had my car relayed form Bristol to my house(bromley) once after a clutch faliure.
Relay is realy.
Old 15-11-06, 01:54 PM   #12
M65
Originally Posted by Tris
I Told me to run for 20 miles or so with the lights off to fully charge the battery. I then ran it the 150 miles home no prob.
Good luck though
And I thought my commute was bad!!
Old 15-11-06, 01:56 PM   #13
Supervox
No more Mr Nice Guy
Supervox's Avatar
Originally Posted by hovi5
IF THE RECTIFIER IS TOAST THE BATTERY IS FULLY CHARGED SHOULD GET YOU HOME
I THINK
I'd think again if I were you !!
If the reg / rec is fried (like my VFR one was until today when I fitted a new one ) it means that the battery won't charge correctly (mine was charging @ 11.5 V with lights - 12.5 without).
I'm surprised that an SV only gets 8 miles - my VFR got me 38 !!
ANDYB - If your commute does not involve much in the way of traffic you might be ok to get home. If it does involve traffic then you can help by winding the idle speed up to max & just try to keep the revs as high as possible without destroying the engine !!
As for RELAY - well I'm with the RAC & on 3 occasions they've taken me (and the bike) home - I thought that was the definition of the cover ?
Never argue with an idiot - he'll drag you down to his level and then beat you with experience
Supervox is offline   Reply With Quote
Old 15-11-06, 02:05 PM   #14
andyb
Thanks again guys, my commute involves a ride @ 60mph for 30mins so hopefully I'll be able to get most of the way home. I'm thinking of asking the missus to follow me home then if I do get stuck she can sit behind me with the hazards on!
Old 15-11-06, 02:26 PM   #15
hovis
IF THE RECTIFIER IS TOAST & THE BATTERY IS FULLY CHARGED SHOULD GET YOU HOME
I THINK
I'd think again if I were you !! WHY??????
If the reg / rec is fried (like my VFR one was until today when I fitted a new one ) it means that the battery won't charge correctly (mine was charging @ 11.5 Amps with lights - 12.5 without).
Old 15-11-06, 02:29 PM   #16
Baph
Hovi5, with the engine using the battery (spark plugs at least), plus lights. It uses power from the battery. Without the reg/rect, the charge is not put back into the battery. It's only a matter of time.l
Supervox, I'm not sure why it only got 8miles, but it was brand new from the dealer, and they'd forgotten to plug the Reg/Rect in, so I know it definately wasn't working. Could of been a partially charged battery I suppose, but I still like to think of it as having a shorter range than a longer one.
Old 15-11-06, 02:51 PM   #17
hovis
i know....been there done that.
what im saying is if he charges the battery,it should get him home
Old 15-11-06, 03:03 PM   #18
Supervox
No more Mr Nice Guy
Supervox's Avatar
Original Quote :-
I THINK
Later Quote :-
I THINK
Spot the difference ???
In your original you didn't use the "&" - this little word changes the whole meaning of the sentence !!
If the battery is fully charged then you're probably right - it should last the journey home - especially the sort of journey that has been described.
Old 15-11-06, 03:29 PM   #19
hovis
I THINK
1) Stop shouting.sorry......mother was vacuming
2) If the rectifier if fubar'd, you'll be good for 8 miles before the battery is flat (applies specifically to pointies, curveys don't have FI, so may run a little longer, but not that much).
Old 15-11-06, 03:44 PM   #20
andyb
Thanks for all the help guys, don't know what I'd do without you! Ive charged the battery at work today so hopefully I should be OK.
Thanks again your all great
Andy
It's Home! Lou M Idle Banter 31 05-01-09 07:13 PM
Home - Work - Home ukrobuk Idle Banter 9 11-04-08 09:19 AM
Crash.NET - Pedrosa: Home pole, home win? NewsBot News 0 03-11-07 07:30 PM
BT Home HUB Help Luckypants Idle Banter 4 07-08-07 10:56 PM
on way home Quiff Wichard Photos 13 15-07-06 11:31 PM
