Old 21-11-06, 07:18 AM   #11
RingDing
RingDing's Avatar
Refitting the airbox on my GSX was always a nightmare. The WD40 tip is a good one but you could also try heating up the inlet rubbers with a hair dryer (or hot water) to make them a bit softer. If you're trying to do this in an unheated garage then the rubber might be less pliable at the moment. I found that used to work, although you have to work quick( and make sure you don't get water in the airbox if you don't use a hair dryer!).
http://ridingalongwayslowly.blogspot.co.uk/
3x Honda C110 - phut-phut-phut
KTM Duke 690 - brum-braaaaaaa!!!!!
BSA C25 - brum-braa-braa
RD350LC Ring-ding-phut-clatter-££££££
RingDing is offline   Reply With Quote
Old 21-11-06, 02:25 PM   #12
gettin2dizzy
and if you do get **** in the carbs don't use a vacum cleaner to get it out....erm.....i've heard it *apparently* dries out the carbs to the point the slides stick. anyone need a hand with their bike this weekend?
Old 21-11-06, 09:34 PM   #13
randallp
Default Thanks!
I thank you all for suggestions and encouragement. A little lube and the top off and it just popped right back on
Seat cowel for 2000 SV 650 s... Tomtoms Stuff Wanted 6 31-07-08 02:35 PM
WTB SV650 $2000-$3000 in So Cal piersurfer Stuff Wanted 1 10-03-08 11:43 AM
lowered seat for x 2000 curvy. sooz For Sale - SV's and SV related items 4 24-10-07 06:13 PM
Seat cowl for curvy custard yellow 2000 SV Ang1234 For Sale - SV's and SV related items 0 10-05-07 07:12 PM
2000 Seat cowl watto Bodywork 2 05-07-04 03:02 PM
