Old 20-11-06, 11:55 PM   #11
21QUEST
21QUEST's Avatar
Originally Posted by Grinch
I've found the worm is a bit of a nightmare, but then where its located it does tend to get a lot of crap thrown at it. I'll have to check mine soon due to the weather I've been riding in...
Exactly and why I cleaned and regreased even though it hadn't done much milage. Bleeding Suzuki could have designed something better me thinks.
Ben
Nemo me impune lacessit.
Old 20-11-06, 11:57 PM   #12
Grinch
Ben
first time I saw it I thought... that's a stupid place.
Old 21-11-06, 12:45 AM   #13
21QUEST
21QUEST's Avatar
Ben
First time I saw it I thought, 'what the fook is that all about' as all the other bikes I've owned have been normal
Ben
Old 21-11-06, 07:59 AM   #14
454697819
possibly got the naked cable instead of the faired one? there is a difference in length?
Old 21-11-06, 09:37 AM   #15
Difference in length, but not in moving length I think (the cable's longer but so is the sheath)
Reeeeally thin plates?
Old 21-11-06, 09:40 AM   #16
Viney
Clutch basket? Im having nightmares as well. Still havent sorted mine
Old 21-11-06, 10:41 AM   #17
21QUEST
21QUEST's Avatar
I did think about that but it's not slipping under hard acceleration. I've hard a couple of bike where I've had to change plates and cables adjustment have not been as bad as this. I'll have to see if I can book a private road and really give it some in first and second gears.
Viney , are saying you have exactly the same problem I'm having?
I know you did change your clutch basket etc at some point. Why did you change it and did you notice a difference(from the whatever the initial problem was) when you first changed it? If so did it feel completely sorted but has now gone back to feeling like it did before the basket swap.
Ben
Old 21-11-06, 12:05 PM   #18
jonboy99
It's just as likely to slip in the higher gears and you're more likely to notice it, if that's what you mean.
Old 21-11-06, 12:16 PM   #19
21QUEST
21QUEST's Avatar
jonboy99, yes that what I mean. It'll take less time/lower speed to get the bike to revs high hence lower gears. Have I missed the mark there?
Ben
Old 21-11-06, 12:22 PM   #20
jonboy99
I see what you mean, but my clutch has been slipping i've always found it easier to tell if it is or not, in the higher gears, top gear really. In the lower gears the revs are rising so quickly anyway i've found it harder to tell. If you haven't got a nearby road you can get up to 80-90 at then you'd probably need a lower gear.
Wherever in the rev range peak torque is rather than peak power, is the rpm to be at.
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
clutch kit sv650nutter149 For Sale - SV's and SV related items 0 25-06-07 03:08 PM
clutch has had it! socommk23 SV Talk, Tuning & Tweaking 8 10-03-06 06:21 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
