Old 30-11-06, 07:10 AM   #11
rictus01
rictus01's Avatar
Originally Posted by MavUK
Cheers all.
One other thing. Whilst the cover is off should I douse everything ina liberal amount of WD to get rid of the gunk that builds up behind there?
Stu
by all means do so, but remember to grease the gear linkage as without it you'll have problems.
Cheers Mark.
Old 30-11-06, 08:27 AM   #12
Viney
Bike info under my user name (in place of location )
It's a 2000, about 20 to 30K miles (and in case it makes a diff it's a continental model - I know that the head lights are different)
Any other info that you need?
Is this a case of removing the front cog cover and checking there? Or is there more to it?
Thanks in advance,
Stu
No, the clutch is on the right hand side of the bike (Brake lever side)
Old 30-11-06, 09:54 AM   #13
MavUK
Thanks in advance,
Stu
But the cable (to checkl first) is on the clutch lever side right?
Stu
Old 30-11-06, 09:57 AM   #14
rictus01
rictus01's Avatar
yes.
Old 30-11-06, 10:15 AM   #15
Viney
Thanks in advance,
Stu
Stu
Ah! Then as rictus said
Old 03-12-06, 01:19 PM   #16
MavUK
OK checked everything (and got soaked in the process - why do things break when it's raining?). Everything appears to be free. I adjusted the cable at the engine end and all seems well now.
The thing I am worried about is why would it do this? I can understand having to make the cable sleeve longer when th ecable stretches, but making it shorter isn't something I was expecting. Can I expect more expense at a later date, or is this somewhat normal?
TIA
Stu
Old 04-12-06, 04:22 PM   #17
RandyO
TIA
Stu
common misconception is that the clutch is adjusted with the cable
WRONG
as posted already, the clutch adjustment is under the front sprocket cover, it is NOT a cable adjustment
there is screw & locknut adjustment that adjusts the clutch
the cable adjustment does not adjust the clutch on either end it adjusts the cable
there should be no need to touch the clutch or cable adjustments between routine minor service every 3500-4000 miles
i think i've only gone and blown it :( wooly SV Talk, Tuning & Tweaking 4 28-12-08 09:20 AM
I've blown up yet another engine!! :( Blue_SV650S Idle Banter 9 14-09-08 04:58 PM
SV blown over. Damn! philh SV Talk, Tuning & Tweaking 8 04-01-07 01:06 PM
Bike blown over...again? JediGoat Bikes - Talk & Issues 8 29-11-06 09:22 PM
