Old 12-12-06, 09:13 AM   #11
Baph
Originally Posted by Moffatt666
I finally saw and rode it today - and I love it! There's only one minor problem though, the speedo spontaneously failed on the A5065 and started working again a short while later. Could this be linked to the restrictor kit? Is it water in the sensor or has something more serious gone wrong?
Usual cause of that is either a broken speed pickup sensor on the front wheel, or an electrical fault. If it's recently had new rubber, I'd suspect the pickup. Pretty cheap to fix, and plenty of information on the forum if you search long enough.
If it's electrical though, that's where it gets fun!
Old 12-12-06, 09:49 AM   #12
the_runt69
Mine stopped and started working when I changed the brake pads recently, found I was crushing the sensor cable between the fork lump and the stop, moved the cable and its worked OK ever since.
H
Old 12-12-06, 10:12 AM   #13
Ping
Hi
Old 12-12-06, 12:21 PM   #14
I had something very like that, but with a curvy... It was caused by a loose connection on the battery. Not sure if the same would happen with a pointy though.
Old 12-12-06, 09:37 PM   #15
Law
Hello!!!!!!!!!!!!!!!!!!!
I would wave as well but this white jacket they put on me is a bit constrictive.
