#11 | ||
![]() So that explains (to me at least) why pointy reg/rects have 2 black&red, and 2 black&white wires ![]() Confused? ![]() |
#12 |
Not arf'.
It's late. ![]() |
#13 |
Because the rectifier uses full wave rectification, but half components on double the outputs, you'd probably get a true (steady) DC level of about 75% of peak too, which would explain why some people have said that whilst revving, the battery should show around 14v. (18v output at peak, 75% is 13.5v - but those are picked from my very dubious memory). But that's getting off topic a little
![]() If all of the above does turn out to be true, it would mean that pointy/curvy rectifiers were completely electronically interchangeable (though maybe not physically). Also, by design (less components == less heat) a pointy rectifier would be less susceptible to failure than a curvy one, but this doesn't take into account manufacturing perspective. Just a thought ![]() Anyhow, time to get some ZZZ's. Let me know how you get on ![]() |
#14 | |
It's exactly the same as the earlier regs, three alternator wires, a hot and a neg, (on this exact unit of which there are two of each).
#15 | ||
#16 |
Haven't quite got it wired up yet due to not being able to get some decent wiring stuff today but will do that tomorrow. Had a look at the rectifier itself and noticed on the back there was a crack and looked like it had burnt out. I guess that is a way of telling if it's buggered?
Its the rectifier i think | shortz | SV Talk, Tuning & Tweaking | 10 | 27-10-07 06:00 PM |
Is it the rectifier? | M1TCH | SV Talk, Tuning & Tweaking | 7 | 26-03-07 10:47 PM |
rectifier | hovis | Stuff Wanted | 2 | 23-09-06 09:25 AM |
Where to buy a SV regulator/rectifier? | falc | SV Talk, Tuning & Tweaking | 8 | 17-08-05 09:43 PM |
Thread split from St Georges Day rideout thread...rant, etc. | RenamedMonkey | South & West Surfers | 24 | 18-04-05 11:16 AM |
