Old 01-02-07, 02:46 PM   #11
Baph
Originally Posted by 600+
I'm fine installing it as I have a spare hard drive to run linux on
I think my main "concern" is to be able to have a usable GUI similar to Windows to assist me in transition and at the same time learn obviously a bit more about the console.
Typical things I do is Internet, Install applications, download stuff, kind of the advanced Windows user if makes any sense to you all
I think the must is the very very friendly GUI
At the moment my home PC has WINDOWS XP and Mandrake on, but if Ubuntu is more user friendly for us newbs I'll put that instead of mandrake
Ubuntu would do that find, but then, so would Mandrake. There's no need to change to do that, unless something didn't quite go right in the Mandrake install.
With Ubuntu Live, you get Firefox & Evolution (web & mail) built in. Synaptic will deal with installing/removing everything natively available to Ubuntu in a couple of clicks of the mouse. OpenOffice will deal with your MicroSoft Office related tasks (and is compatible with the MSOffice files!) No need to even bother running off to the shops to get hold of the software, so long as you're connected to the internet.
Of course, all of this applies to most of the desktop distro's out there, not just limited to Ubuntu, but the names of different applications that do the same job change.
Old 01-02-07, 02:49 PM   #12
600+
With Mandrake you don't get a GUI to install things so you have to do it via console. A bit of a big step for a newb I think. Tried it to install java for example and that messed up my firefox big time No need to mention trying to install firefox2......erm that was a big no go LOL
Hence why I would like to have a GUI to do all that at this early stage.
Old 01-02-07, 03:07 PM   #13
Ceri JC
Originally Posted by Grinch
True, yes... But I still find it p*ss easier to us now, I was surprised how easy as a few years ago I tried and just couldn't be arsed.
I would say give it a go, the worst that is going to happen is you'll just put Windows back on.
Any recommendations on a flavour that can host Oracle without too many problems? Ideally one that can also be stored as a vmware image too, without to many headaches?
TIA.
Old 01-02-07, 03:11 PM   #14
Baph
That's something I wasn't aware about with Mandrake.
I setup Ubuntu on my dad's machine a few days ago. I can confirm it's a GUI installer, and there's something like 4 screens to it. It'll pretty much setup everything for you.
As for java, I write in java for work, and we use the Eclipse IDE, which is entirely written in java itself. I merely downloaded Eclipse (it's not part of Ubuntu) and it ran happily (java doesn't come with it, but it depends on java). I didn't check which version it is, but I'd imagine it's either 1.4 or 5.
Old 01-02-07, 04:06 PM   #15
philipMac
TIA.
You might find that Oracle will bring out its own flavour of Linux.
In the mean time, I would look at RHEL or CentOS.
here is something to get you started mate.
http://www.idevelopment.info/data/Or...LINUX_12.shtml
http://www.idevelopment.info/data/Or...USTER_10.shtml
wrt security, Vista is, and never will be more secure than Linux. Nor will XP. Nor, I would imagine, will any closed source OS, unless it is highly obscure.
Old 01-02-07, 04:18 PM   #16
Grinch
TIA.
I would say don't... bloody Oracle just causes me headaches. Not played with vmware yet, but I have seen threads about it on the ubuntu forum.
Old 01-02-07, 04:32 PM   #17
philipMac
A mate of mine has Oracle running away fine with his big CentOS cluster.
No problems at all he says.
There are RPMs, it just works apparently.
(I dont use it, because I want fast SELECT speed, so I use MySQL.)
Old 01-02-07, 04:39 PM   #18
SoulKiss
SoulKiss's Avatar
Debian for choice here - which is Ubuntu for men
Best way to think of it is
SV650N-X1 - Debian
SV650S-K6 - Ubuntu
I would say Ubuntu for a newbie tho.
Mind you, as I have gnome installed you would be hard pushed to know its not Ubuntu at a glance
David
Old 01-02-07, 04:47 PM   #19
timwilky
timwilky's Avatar
TIA.
Yup, we do this with RHES. We must run about 10 separate oracle instances on VMs
Not Grumpy, opinionated.
Old 01-02-07, 05:24 PM   #20
600+
I think we have made up our minds
Mandrake is comming off and i'm installing ubuntu
I made Linux work Jayneflakes Idle Banter 37 18-07-08 09:44 AM
Any Linux Users in here? startrek.steve Idle Banter 18 23-06-08 12:35 PM
Nero 3 Linux Baph Idle Banter 17 26-04-07 03:01 PM
Linux help wanted! thor Idle Banter 53 18-11-06 01:55 AM
linux query Gnan Idle Banter 3 30-01-06 04:15 PM
