Old 07-03-07, 09:20 PM   #11
ejohnh
Default Re: GSXR brakes pulsating
Have you checked for grease(burnt on) on the disc?
Old 07-03-07, 09:44 PM   #12
zunkus
Interestingly I was reading the following about used GSXR's in TWO March magazine;
Brakes: The only weak point of the original K1-K2 model. Pads and fluid overheat quickly and the only cure is softer pads and braied hoses. Things improved massively with the K3/K4's radial numbers,although these suffered a little fade - as did the earlier calipers, a brembo master cylinder fixes this. Some K3-K6 models suffer from intermittent vibration from the front brakes at low speeds. It's possibly the sintered pads and is nothing to worry about.
Old 07-03-07, 09:53 PM   #13
21QUEST
21QUEST's Avatar
Was that the 750 or the 1000? If I had to I'll guess they were talking about the 1000.
Anyways if those journos actually looked at the bikes they ride, they'll know the 1000 has braided hoses (ok ..the loop over line is braided). .
I'm sure they have a point....
Ben
Nemo me impune lacessit.
Old 07-03-07, 10:00 PM   #14
zunkus
The article was about buying used GSXR1000's
I think a change of pads is agood, cheap idea. I'm sure the discs are not warped, they'd show imidiately even at very low speeds.
Old 07-03-07, 11:07 PM   #15
tinpants
Ubique
tinpants's Avatar
Would it be contaminated brake fluid? Or a seal on the way out in one of the calipers?
I'm not sure about this. Just chucking a few ideas around.
Jesus loves you. Everyone else thinks you're a pillock
tinpants is offline   Reply With Quote
Old 08-03-07, 08:50 AM   #16
andyb
Cheers for all the advice. Will print all this out and have a look. Probably wont have time until the weekend though. At least I have something to go on
Old 08-03-07, 11:18 AM   #17
John 675
Originally Posted by andyb View Post
As some of you know just put a GSXR750 front end on
Got any pics of that im thinking of doing the same as that
Old 08-03-07, 11:28 AM   #18
andyb
Not as yet, keep forgetting to take some. Will post some up ASAP though.
Old 08-03-07, 11:19 PM   #19
BILLY
Here you go
Old 09-03-07, 07:55 AM   #20
21QUEST
21QUEST's Avatar
Originally Posted by BILLY View Post
Here you go.....
Show off
Looks good though
Ben
GSXR Calipers & R6/GSXR Master Cylinder Steve_God Stuff Wanted 4 16-02-08 06:30 PM
SV GSXR Fork Swap - Keep Stock GSXR Damper? Mesomorphman SV Talk, Tuning & Tweaking 5 08-09-06 07:40 PM
Swap GSXR forks/radial brakes/radial master cylinder/wheel Teknic SV Talk, Tuning & Tweaking 2 16-03-05 07:19 AM
