Old 26-03-07, 07:08 PM   #11
monkey
Default Re: How do I free a caliper that's siezed onto a disc?
Cheers mate. Got brake cleaner and after cleaning all parts sprayed seals, piston and caliper where fluid will go. Have refitted it and bled the system. As I used a normal bit of tubing I just left the nipple open, put the end in fluid and kept pumping the brake whilst topping up the reservoir. When the bubbles stopped I tightened the nipple with the pedal down and topped up the reservoir again. This should have done it ok right? As far as I can tell without being able to take the bike for a ride the brake seems fine. Lovely job.
Thanks for you help.
Maybe when it's running I'll check and bleed the brake again.
Old 26-03-07, 07:16 PM   #12
Dan
It'll certainly do most of the bleeding - although it's always advisable to use the pump-slacken-tighten-release method to really do a good job, but for a rear brake it'll probably be fine as it's a single-point system.
If you're regularly doing little bits and bobs, it's well worth investing in a one-man bleeder - I wouldn't go mental and buy a MityVac unless you're using it a lot, but you can buy a dual circuit non-return valve job from Halfords for about £14.99 - and you can do both front calipers at once.
Old 29-03-07, 12:20 AM   #13
monkey
Cheers. Will get the missus to do the pumping next time and I'll do the bleeding. Got her going tonight! Lovely job.
Old 29-03-07, 07:17 AM   #14
Dan
Are you still talking about the bike, or the pumping missus?
FREE (ish) disc lock hovis Idle Banter 9 23-11-06 01:43 PM
Free Oxford disc lock at Busters lukemillar Idle Banter 37 16-08-06 09:27 AM
rear caliper pad pin siezed mec SV Talk, Tuning & Tweaking 12 23-05-06 07:04 PM
Smaller rear brake disc and caliper.... anyone? Vtwinlover SV Talk, Tuning & Tweaking 2 17-07-05 07:28 PM
Single disc with four piston caliper pridhac SV Talk, Tuning & Tweaking 19 23-09-04 02:04 AM
