Old 11-04-07, 05:18 PM   #11
hovis
Default Re: Ignition Retarder
cool, i plan to do it mid ride-out to see if i can tell the differance
Old 11-04-07, 05:28 PM   #12
Born again
Its easy, if you take your time it could take you sixty seconds and thats with a break...........and its free.....
Old 11-04-07, 06:12 PM   #13
danf1234
This might be a daft question but does this mod do exactly the same as a G-pack thing that just clips into the loom??
Dan
Old 11-04-07, 06:20 PM   #14
phil24_7
Does it do the same as the smart TRE too?????
Old 11-04-07, 09:44 PM   #15
hovis
yes & yes
AFAIK
Old 11-04-07, 10:04 PM   #16
phil24_7
Guess I'll add it to the list of things to do then!!!
Old 12-04-07, 08:22 AM   #17
Blue_SV650S
Not that simple, it basically moves the power up the rev range so you don't get more at full power (or if you do, it's irrelevant) but you get a tiny wee bit more at lower revs. ...
I think that is slightly misleading Northy ...
The retard circuit is active between say 3-4000 rpm (can't remember exact revvs, and can't be bothered to look it up ) .. in 2nd and 3rd ... so it will not effect outright power in 2nd or 3rd (like northy said) ... however there is no actual addition or 'moving' (where I think it is a bit misleading northy) ... just a bit of subtraction in the 3-4k mark with the device activated .... so all this mod will do is give you back the little bit that the retard circuit would have robbed in the 3-4k area
The actual power loss and if it is detectable is debatable, but it WILL be loosing you power ... its free to eliminate (on the curvy), and it won't do the bike any harm, so why not?!??
Oh and can someone make a note of where the wires are in the connector as I need to put them back on my trackbike and I can't remember which one went in which hole
Old 12-04-07, 08:42 AM   #18
Born again
Connector#3-red/yellow
Connector#4-green/blue
Old 12-04-07, 09:01 AM   #19
Blue_SV650S
Ta ,
But just to clarify, is that looking from the back of the plug 'wire in side', or the 'mating' side
I presume its as if I was looking at the mating side of the plug i.e. The 3rd pin on top row (left to right) is the red/yellow right?!?!!?
To be honest the pin numbers might actually be molded in the plug ... I can't remember and not near my bike to look
Old 12-04-07, 09:17 AM   #20
Born again
Yes that is looking at the mating face, ie looking at the end you would put the blade in to release the wire. Numbered left to right........
ignition retarder BIKER-DENE SV Talk, Tuning & Tweaking 29 08-03-07 12:17 AM
2nd & 3rd gear ignition retarder removal localhost SV Talk, Tuning & Tweaking 1 19-04-06 05:38 PM
Disabling ignition retarder - worth it? red5 SV Talk, Tuning & Tweaking 9 29-03-05 04:02 PM
Ignition retarder peterjohnwood SV Talk, Tuning & Tweaking 1 11-03-05 10:31 AM
Ignition retarder Dicky Ticker SV Talk, Tuning & Tweaking 1 09-03-05 07:35 PM
