Old 10-04-07, 09:24 PM   #11
Default Re: About Drive Chains
If the slightest care is taken in assembling the rivet link it won't be tight, think on this when you consider who fits your chain.
Some chains - Regina for instance - come with shims to fit into the link as you rivet it so it will be exactly the same width as all the other links and the 'O' or 'X' rings will seal correctly, the same can be achived with a caliper and a little care when assembling.
Old 11-04-07, 02:34 PM   #12
petevtwin650
Originally Posted by ejohnh View Post
One of the main reasons I got this bike was to do all the stuff myself. So if that means taking off the swing arm and putting on an assembled chain then I can do that. In fact that will save me messing around getting stuff riveted. I'm gonna need a way to support the backend without the paddock stand, to take off the swing arm.. mmm Dont mention the abba!!!
Certainly it's worth doing it this way if you intend to keep the bike a while. As Northwind says, the pivot bearings will almost certainly be in need of some fresh grease.
You'll need a special socket to undo the swingarm locknut too.
Think someone is running a thread about supporting the back end without a paddock stand
Old 11-04-07, 02:36 PM   #13
ejohnh
If you buy from B&C Express they can supply clip and rivet links for most if not all their chains...
Having said that, the swingarm pivots never get serviced, it just never ever ever ever happens, and it should. So that's sort of in favour of endlesses.
Good comment! Eileen's done just over 10k now. Maybe I will service the SA pivot .
Old 11-04-07, 02:40 PM   #14
ejohnh
How special is the socket? I have most sizes up the about 36mm.
Old 11-04-07, 02:46 PM   #15
petevtwin650
Check out this thread for ideas
http://forums.sv650.org/showthread.php?t=83857
Old 11-04-07, 03:03 PM   #16
ejohnh
OK I checked that thread and looked thru all my old rusty sockets - and I do have a 27mm one. What do I do to it to make it an OK tool?
Old 11-04-07, 03:07 PM   #17
petevtwin650
Grind or file it until it looks like the one in my pic on the other thread or use the nut on locknut on Eileen to make a pattern I guess.
I cheated and bought one.
Chains Draper Bikes - Talk & Issues 19 10-06-07 11:14 AM
Chains etc ?? help G SV Talk, Tuning & Tweaking 8 05-05-07 01:03 AM
chains weazelz SV Talk, Tuning & Tweaking 3 16-10-06 11:30 AM
Chains and Sprockets tricky SV Talk, Tuning & Tweaking 10 14-06-06 10:00 AM
Chains diamond SV Talk, Tuning & Tweaking 13 16-03-05 03:55 PM
