#11 | |
The problem with dropouts only with ethernet connected PCs sounds more like a router hardware failure though. |
#12 |
OK time to start the testing on the master socket and the test sockets
#13 |
i have to say that connected from the master socket it appears that I can connect to the maximum speed from my provider and its stable as well (for the time being)
so I guess my extension socket was fooked :S I'll now wire it with Cat5e cable as well so that should be a bit better |
#14 |
just to rub it in! I can now connect to my broadband via my pocket pc - so i'm always here! scary, huh?
#15 |
LOL not really :P
I can do that as well |
#16 | |
![]() I've worked with a lot of setups that reported random dropouts in connection. Even some that had no connection at all on one socket, and a connection on another socket. Always plug your equipment into the master socket if you have any problems, if you're still having problems when wired into the master, investigate it. |
#17 | |
If the line is severed for example, they have to come out & fix it. The only time you call your ISP, is when your broadband doesn't work. Then they call BT (if needed) & BT come out to do the necessary work. |
#18 |
#19 |
Baph you're right but I didn't have that problem 2 weeks ago when I got disconnected from my previous ISP hence why I didn't look into that straight away.
Eagle747 I never said different ![]() |
#20 |
Oh yea, when you're routing that CAT5e, be careful of mains power as well. Perpendicular not parallel, otherwise you'll get issues again.
Wireless Connection Help | Miles | Idle Banter | 4 | 31-12-08 07:39 PM |
Electrical Connection Help | NavalNGuy | Bikes - Talk & Issues | 0 | 09-04-07 01:36 PM |
slow broadband connection | Shinsei Jutsu | Idle Banter | 8 | 27-06-06 07:08 PM |
CCC connection diameter | Reckless Rat | SV Talk, Tuning & Tweaking | 1 | 15-05-06 04:26 PM |
Broadband connection issues... | Cloggsy | Idle Banter | 13 | 10-02-06 12:16 PM |
