Old 09-05-07, 05:19 PM   #11
Default Re: Lockup
just knock down the gears anyhow and enjoy the slide
Old 09-05-07, 05:34 PM   #12
ASM-Forever
Default Re: Lockup
Hitting neutral wouldn't be an issue if you wern't shifting down to 1st in corners....carry more speed....no need to go down that far
Old 09-05-07, 05:44 PM   #13
sinbad
Default Re: Lockup
I only ever change down to first at walking speeds and lower, second gear is short anyway and I'd rather just slip the clutch ever so slightly.
The blipping is easy to practice, because you don't have to be on the brakes to do it, and as a novice you'll probably be smoother by using the brakes as little as possible anyway. Doing it whilst braking is quite a bit harder, because your right hand is doing two things. Just make sure that you have the brake lever set to a very comfortable position, and use two fingers on the brake (you can get used to that separately, without blipping, too).
Old 09-05-07, 07:32 PM   #14
Endellion
Default Re: Lockup
All good advice, glad Its not just me!
Will practice this when I am out next, it all makes sense cause this is what I do in a car...duh!
sinbad, I have been advised not to use 2 fingered braking, is it ok?
Old 09-05-07, 07:43 PM   #15
Alpinestarhero
Default Re: Lockup
Two fingers are fine, I prefer three but two does work; just remember that you'll feel like you need to queeze a bit harder with two!
My dad uses his three fingers from the little one to the index finger, and thefinger next to the thumb stayed wrapped around the throttle; i tried this, it does work very well but feels really strange!
Matt
Old 09-05-07, 07:45 PM   #16
jamessunhill
Default Re: Lockup
Hi Ian. How are you enjoying the new found freedom?
I'm loving mine. My main vehicle (Land Rover) is currently looking a little rejected (not been driven since Sunday when I picked it up from the train station).
I went out last night for a play (some lovely twisties near me and almost no cars in the evening). I had exactly the same thing a few times, but I'd been warned about it buy a few guys on here and so was expecting it. First one was a little disconcerting, but when I did it after that, my grin just got bigger
Old 09-05-07, 07:50 PM   #17
Stu
Trinity
Stu's Avatar
Default Re: Lockup
How should i perform the "blip"? I normaly do it as i shift the gear, i.e. clutch, gear+ blips, clutch out.
Or should i
Clutch in, gear, blip, clutch out? i.e. all separate?
All i know is that if i dont blip, its not a smooth downchange as the clutch re-engages
Matt
All you have to achieve is to let the clutch out after you have finished blipping or you will lurch forward on acceleration.
And let it out before your blip has died away to nothing. The rest is just practice (and trying not to over blip would sort out problem one - but not sound as good!)
Old 09-05-07, 07:58 PM   #18
sinbad
Default Re: Lockup
If it were wrong they wouldn't sell gloves like these
http://www.getgeared.co.uk/acatalog/201956_palm_PU.jpg
I understand why they advise newbies against it, if you're not careful you can twist the throttle a bit whilst you're braking, but the advantages outweigh that. You can be covering the brake all the time through built up areas, for example, which cuts the reaction time significantly.
Old 09-05-07, 08:02 PM   #19
Beenz
Default Re: Lockup
Clutch in, gear change while short blip (more so if the engine is reving higher) clutch out as the blip revs are falling and not rising.
I had to learn this back in the days of a shaft drive v twin and do it all the time now.
Just practice, you don't have to be spot on with it, a secondary benefit is the reduced stress on the drive train.
Old 09-05-07, 09:00 PM   #20
Endellion
Default Re: Lockup
Lol sinbad, nice gloves, It was my instructor that advised against, makes sense for newbies but I will try this 2-3 fingered approach next time I am out.
Hey James, I am totally addicted and getting out as much as possible, done a few hundred miles since weekend picking bike up and even though i am meant to be breaking engine in its too tempting to give it some now and again but I am learning heaps, all the guys and gals on here are v helpful.
Got a weekend of v twin fun planned....you?
Shared lockup in Edinburgh anyone? GCampbell Stuff Wanted 0 08-10-08 01:22 PM
