#11 |
Hmm time for me to check the play in mine then!! I'll see if I can find someone to sit on it while I check.
#12 | |
#13 | |
#14 |
Different sorts of wear really... The force that wears out the sprockets is also wearing out the chain, but I reckon most chains get damaged or replaced before that ever becomes an issue anyway. Same with the o-rings, they do wear over time as the chain flexes. Don';t know what the real answer is, just know that the argument that only neglect wears out chains is nonsense.
There's some sort of tourer with an oil-bathed chain isn't there? I think maybe Randy O has one?
#15 |
Another slightly OT question,
is there anywhere that sells better, replacement, chain alignment things for pointies? I find them nearly useless, the one on the left always twists around a bit making the markings all but redundant. |
#16 |
Anothr point : The pins and rollers are made of mild steel, "case hardened" by carburising or nitriding, this creates a thin surface layer about 0.02mm thick of very hard steel surrounding the soft mild steel core (we do the heat treatment where I work).
So the chain will wear slowly until the "case" wears through, then wear will be very rapid. I've seen this happen to my chain - after years of little adjustment, all of a sudden you have to adjust it every few days! Time for a new chain! I suppose you could calculate roughly how much stretch before the case wears through, but I can't be arsed at the mo ![]() |
#17 |
using autosol on the links doesnt help much.
Uneven chain wear | rockster | SV Talk, Tuning & Tweaking | 17 | 16-05-09 08:03 PM |
Longer chain makes a difference? | zunkus | SV Talk, Tuning & Tweaking | 27 | 31-03-08 10:00 PM |
Chain wear | yorkie_chris | SV Talk, Tuning & Tweaking | 20 | 14-11-07 08:50 PM |
Mixing chain wear | tomjones2 | SV Talk, Tuning & Tweaking | 1 | 29-04-07 02:26 AM |
Lack of forum-ing.... | Skip | East Anglian Revolution | 5 | 09-10-06 09:52 PM |
