Old 13-06-07, 11:34 AM   #11
plowsie
Default Re: Pillion Set Up
Originally Posted by Tim in Belgium View Post
Plowsie, you won't have any preload adjustment on the front unless your bike has been uprated with K2 preload adjusters, so you've just the back to fiddle with.
Thought so and theres the confirmation from minimatt lol. Cheers for the help though guys!
Old 13-06-07, 11:36 AM   #12
plowsie
Thanks for all the help guys. Might have a play 2nite to see how we feel.
Old 15-06-07, 11:32 AM   #13
plowsie
Sorry for bringing my own thread back to life, but looking at the bike yesterday before it went off to get fixed with the airbox problem, the supspension is already on top setting. I've been riding it for 8 months with my suspension too hard. Could this be the answer to my leaning and cornering problems? Also riding like this for 8 months may it have affected the suspension itself?
Old 15-06-07, 12:01 PM   #14
Baph
You were looking at pre-load, not stiffness. I'd argue that pre-load, by the very nature of what it does, will affect stiffness a little but it's arguable as to whether it's a noticable amount.
Pre-load will denote the bikes overall geometry though, which will affect how the bike turns into a corner, and the stability in the corner should you hit any bumps etc.
Old 15-06-07, 12:29 PM   #15
The preload will not affect the stiffness of the suspension. The only way to make the suspension harder or softer is to change the springs.
For the 'N'th time: Preload only changes your position in the suspension's available travel under any given load. Raising the rear preload of the suspension of a modern motorbike with a rising rate suspension system will actually reduce the apparent spring rate as, for any given load, the suspension will be further extended and thus the linkage in a lower section of the rate curve.
Black pillion seat cowl and pillion grab rail off K8 Nobbylad For Sale - SV's and SV related items 3 23-12-09 11:05 AM
Going Pillion G Bikes - Talk & Issues 33 31-05-08 10:56 AM
pillion age? kwak zzr Bikes - Talk & Issues 20 14-06-07 01:21 PM
Pillion NAPA121 Bikes - Talk & Issues 16 29-03-06 10:43 AM
SV after a pillion beefcake Bikes - Talk & Issues 13 03-09-05 11:15 PM
