#11 |
narr my 650 has gone
#12 |
guys on the sv1000 portal recon it could need the idle turning up a tad as its only ticking over @ 1000rpm? also try the throttle control mod.
#13 |
upping the rpm idle and some FI cleaner seems to have sorted the problem.
#14 |
How many miles has it done now?
If you get similar problems, might be worth getting the throttle bodies synced as Rictus said. Mine used to run rough on a constant throttle at 3-4k revs - syncing the throttles at the 7500 service sorted it.
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S ![]() |
#15 |
3.5k miles? i'll try the cheap options first, like i say its only pulling away from idle it does it (every now and again), once on the move it seems to dislocate your arms fine
'99 SV650 SX Running problems | MacDaddySV | SV Talk, Tuning & Tweaking | 11 | 20-02-09 07:52 PM |
Running problems since new battery | svrash | SV Talk, Tuning & Tweaking | 5 | 09-01-07 09:49 PM |
Running problems | watto | SV Talk, Tuning & Tweaking | 4 | 10-11-06 11:54 AM |
Running Problems | Marshall | SV Talk, Tuning & Tweaking | 22 | 09-10-06 09:27 PM |
Running Problems | Claire | SV Talk, Tuning & Tweaking | 6 | 12-12-05 09:05 AM |
