#11 |
If it's an S you could try a double bubble screen and a tank bag to lean on a bit.As for fuel consumption,the cheapest mod must be one tooth up on the front sprocket costing about £12.The bike is good for the mileage as long as you change the oil regularly and keep it serviced.
#12 |
The SV should be fine for fuel.
Are you talking comfort? A Bandit 6 would be ok and cheap. The 500cc twins are good for fuel and tank range...and comfort. A Pan Euro or Blackbird...or any BMW. |
#13 |
It's got to be the Deauville, boring workhorse but motorways and commuting is it's niche.
#14 |
#15 | |
![]() ![]() My commute, from home to where I park by work, the odometer reads 49.7miles. I can choose to do a little more distance and go other routes if I want, but the shortest route is just shy of 50miles, almost entirely on the A55 (tantamount to a motorway). I've changed the gearing to get more acelleration (2 up on the rear sprocket). I've also got a Fabbri DB fitted, a loud can with baffle removed, snow shovel has gone, and a small plate (7x5). The last tank, I got 147miles (I think - put petrol in this morning). The tank before that was 170 miles on the dot! I put 15.66litres in to fill it up, so still had 1.3litres left to play with. The light was on solid though. I generally fill the tank every 3 journeys (day & a half if you like). Before I changed the gearing, she'd comfortably cruise along at 120, but now 120 feels like you're pushing it a bit hard, so I generally cruise around 100 (all numbers are in kmh officer!!). Generally, it runs 500 rpm higher in 6th to hold 70mph, which no doubt uses a little more jungle juice. Overtaking is overtaking is overtaking, and the SV definitely doesn't complain. Comfrot, not an issue for me & genuinely never has been. I started life on the SV commuting this distance, and it wasn't like I needed to get used to the seat, the seat kind of moulded around me. Generally I ride with a tank bag, and pretty much lay down on it. This will help reduce drag but also I find it makes it more comfortable as your weight isn't on your wrists any more. Its also fun being able to close the throttle & sit bolt upright & use the air as a brake, or is that just me? ![]() The DB helps a lot as it directs wind around me perfectly. Still get it on the head/shoulders unless I tuck down, but sometimes it's a bit welcomed to be honest. The thing that will probably hit you hard is the servicing schedule. 50miles each way works out at 500miles a week!! That means services come & go approx every 8 weeks, faster if you use the bike for pleasure too (like I do). You quickly learn how to service the bike yourself if you don't already know. Anything else you want to know, just shout ![]() |
#16 |
So it looks like a DB screen is almost essential, however Baph, you seem to have gone 2 up on the sprocket for more acceleration rather than (say) 2 down for increased economy.
Has anyone gone for the more sluggish but better mileage sprocket? How much of an effect does it have on economy? |
#17 |
#18 |
Is a bigger tank a possibility?
Even looking at the Deaville the tank range is only around 180miles. Surely manufacturers must have thought that some people do high mileage! |
#19 |
#20 |
Speak to Lynn, she has a CBF1000, which I reckon could be exactly what you need.
Want a quiet lid ? Schuberth S1, no contest.... (Both my own opinion of course...) |
125cc on a motorway!? | Tomtoms | Idle Banter | 92 | 15-01-09 02:53 AM |
Has anyone been done for speeding between 70 and 100 on a motorway? | monkey | Bikes - Talk & Issues | 33 | 30-04-08 09:59 AM |
Motorway Debris | Beenz | Idle Banter | 28 | 09-01-07 05:58 PM |
Motorway fun | rpwoodman | Idle Banter | 6 | 02-11-06 10:39 AM |
Motorway Madness | I'm_a_Newbie | Bikes - Talk & Issues | 28 | 12-09-06 10:52 AM |
