Old 29-07-07, 10:12 AM   #11
riktherider
Default Re: Arrgh! battery problems
i need to go through the whole whole electrics with a multimeter, becasue i think i have a couple of other problems. its running fine now, still havnt replaced the reg rec or the batetry, but will do it soon. only been doing short trips though. wouldnt trust it going any further. hasnt blown any bulbs or change in brightness at different rpm.
Old 29-07-07, 03:47 PM   #12
Originally Posted by Jimz View Post
a faulty regulator can take out the generator so the best thing is to messaure the volts, wich i havent done yet, to fu**ing lazy, shold be around 14v i think.
By test the generator they mean actually check the 3ph hot wires (yellow ones going into the reg-rec) coming out of the generator, IIRC it should be 50vac or thereabouts phase-phase (can check haynes for you if anyone needs the exact)
Chris
Battery Problems SV Meldrew SV Talk, Tuning & Tweaking 9 04-02-09 10:54 AM
Charging/battery problems turbominimagic SV Talk, Tuning & Tweaking 8 28-10-08 11:01 AM
Battery problems gerbrox Bikes - Talk & Issues 4 21-08-08 12:31 PM
Running problems since new battery svrash SV Talk, Tuning & Tweaking 5 09-01-07 09:49 PM
Battery Problems Dom_ SV Talk, Tuning & Tweaking 7 19-06-05 10:10 AM
