Old 28-07-07, 06:07 PM   #11
RhythmJunkie
Default Re: how do i jump start my bike
Doesn't bump starting damage the cat? We were advised never to bump start our car for that reason! Maybe we were given twaddlevice??
Old 28-07-07, 06:09 PM   #12
RhythmJunkie
Isn't there a plunger/activator that can be taped down while you get her started? You know....make her think that her clutch is pulled in?
Old 28-07-07, 06:48 PM   #13
Bump starting cars can put too much fuel through and damage the cat, but on a bike who gives a ####? you don't need to pass an emissions test.
Old 28-07-07, 06:52 PM   #14
RhythmJunkie
No emissions test for bikes? Oh wow....how cool is that! Yippeeee!
Old 28-07-07, 08:34 PM   #15
Dan
Isn't that what your left hand's for?
Old 29-07-07, 12:04 AM   #16
Yeah but we're on about bump starting where you have to let the clutch out, read the thread man!
Old 30-07-07, 08:38 AM   #17
John Burt
Changing tack, before you bump start direct to the starter it's better to have a little bit left in the battery, if its totally flat the spark will be very weak. Yeah I know that eventually the alternator ignitor windings will generate but its better with a bit of battery assist - trust me I've been there.
Old 30-07-07, 09:54 AM   #18
Dan
But the clutch interlock switch AFAIK only inhibits the starter button, not the ignition or ECU (if it inhibited either of those the engine wouldn't run once started with the clutch out), so bodging the switch to pretend like the clutch is pulled in wouldn't serve any purpose... simply pulling the clutch in (which you'd have to do anyway) will disable the interlock.
Old 30-07-07, 10:09 AM   #19
correct. But somebody said bump start and try the electric start simultaneously, which with the clutch switch in place doesn't seem practical.
Old 30-07-07, 01:13 PM   #20
jambo
jambo's Avatar
Some people advocate this. I've never had a need. Bump in 2nd or 3rd down hill or with a push, No need for the starter or any worry about the safety cut outs.
Jump start question. PJinUK SV Talk, Tuning & Tweaking 7 01-12-08 01:37 PM
Old owner used to jump the bike with the car running....help andyfordceo SV Talk, Tuning & Tweaking 20 09-11-08 03:04 PM
To jump or not to jump: special red light circumstance MeridiaNx Bikes - Talk & Issues 23 15-11-07 12:59 PM
Jump-leads from car to bike .. Advisable..? Eggspit Bikes - Talk & Issues 9 09-12-05 12:07 PM
Can i jump start my bike with jump leads (Like my car!) Freeloader SV Talk, Tuning & Tweaking 3 08-12-05 06:46 PM
