Old 08-08-07, 09:52 AM   #11
Viney
Default Re: Horrible Metal Scraping Sound
Its probably the clutch. I wouldnt say its like metal against metal sound, but a sort of groan, much like a deeper verison of when you used to have wet brakes on a pushbike?
Old 08-08-07, 09:53 AM   #12
plowsie
hmmm yer maybe that sorta sound yer, i'm gonna go out at lunch and test what sort of revvs it happens at
Old 08-08-07, 10:09 AM   #13
Viney
Mine does that. Not all the time.
Old 08-08-07, 10:10 AM   #14
plowsie
Yer its not all the time, seems more when i set out first time, once she's warm its all good. Ever looked into it?
Old 08-08-07, 12:23 PM   #15
Jase22
Mine makes that noise when the engine isn't warmed up.
Solution: take it easy until the engine warms up.
Old 08-08-07, 01:11 PM   #16
Viney
Yep, Replaceds the Entire clutch (Basket, plates, steels, worm drive thingy, cable, bearing) still does it every now and again.
I have other issues with my clutch though.
Old 08-08-07, 01:25 PM   #17
Mine did that too, for a long time- only ever when it was fairly cold, so I put it down to something in the clutch sticking, it'd usually deliver the power with a jerk too. Replaced the clutch with one of my spares, which doesn't do the CRUNCH but does rattle a lot
Old 08-08-07, 03:43 PM   #18
Captain Nemo
if youre not sure what it is then get it checked out "metallic crunching noises" are never a good thing................better to spend £30 having someone look it over than £400 getting stuff fixed................
Old 08-08-07, 09:55 PM   #19
toonyank
Originally Posted by stewie View Post
Hi, no expert on these things but sounds like clutch to me, cos pulling away put max pressure on clutch, could be pressure plates ?
Hmmmm, yes it sounds like that's what it could be IMHO. See if you get the same result if you feather the clutch only not in 1st unless you do wheelies (disclaimer ). Starting off is the only time your clutch slips at that degree until it bites unless of course you do wheelies and then you might hear it again.
Old 09-08-07, 08:37 PM   #20
have you got yer steel toe caps on and ran over your own foot?
scraping footpegs through the corners coldtyres SV Talk, Tuning & Tweaking 31 01-11-08 04:58 PM
Peg Scraping! Need more clearance! dmracing SV Talk, Tuning & Tweaking 13 22-08-07 03:15 PM
Scraping the bottom of the barrel jonboy Idle Banter 8 05-05-06 04:05 PM
Hugger scraping the wheel? carty Bikes - Talk & Issues 1 12-04-06 01:59 PM
pads and discs scraping rob13 SV Talk, Tuning & Tweaking 9 09-02-06 06:42 PM
