Old 10-09-07, 08:04 PM   #11
Alpinestarhero
Default Re: When do you shift gears ?
Google "Peugot Speedfight 100"
Beasty machine
Twist and go
Loud exhaust due to a hole, somewhere
Rockin'
Matt
Old 10-09-07, 08:24 PM   #12
skidmarx
Originally Posted by mdcvjd View Post
Hi,
I recently purchased my first SV650 (first bike). I was expecting a more powerfull bike. I think it might because I tend to shift to early, usualy never go 5000 RPM.
I am just curious as to when more experienced drivers tend to shift...
thanks
Sounds like you have either had, or would like, a Harley
Old 10-09-07, 08:26 PM   #13
toonyank
Hi,
thanks
I do agree it's a bit of a beginners bike.
There are plenty of 600's with a higher power/weight ratio but I think it should be just fine in you case.
I know it's your first bike, but it does red line at 10,500 RPM so why say you've expected more power when you've only used less than half the revs.
Old 10-09-07, 08:29 PM   #14
sinbad
Next time you're out bimbling about, once it has warmed up, put it in second, find a nice straight piece of empty road, ride along at 4.5k rpm and then open the throttle fully and don't change to 3rd until 10k rpm.
Old 10-09-07, 08:34 PM   #15
ThEGr33k
You can ride at 30MPH in 6th and it isnt too bad at pulling upto 60 in that gear either imo. If im going for it take it upto 11,000 revs (red line on k3>).
Old 10-09-07, 08:35 PM   #16
toonyank
Yeah like sinbad said only it may create skidmarx for a beginner or maybe you were on a Harley
Old 10-09-07, 08:39 PM   #17
toonyank
Ooooo I did realise there were 500 more revs nice
Old 10-09-07, 08:40 PM   #18
leon c
Originally Posted by Jackie_Black View Post
Just wring its neck it'll go fast you'll get scared. Job Done
CORRECT A+
Old 10-09-07, 08:42 PM   #19
sinbad
TBH I don't think they're worth using, it seems to die off past 10k and you're better changing up. Although someone might produce a nice graph to prove me wrong.
Old 10-09-07, 08:42 PM   #20
Jackie_Black
Mine seems to have even more of a kick after about 8500 rpm too. Which is nice and its getting faster the more miles i put on, woo hoo.
Quick shift Bill.Cross SV Talk, Tuning & Tweaking 18 02-03-09 11:53 AM
Gear shift rod Sean_C SV Talk, Tuning & Tweaking 3 21-02-09 08:04 PM
Bike Won't Shift Down. mikebrooman SV Talk, Tuning & Tweaking 22 22-01-09 05:28 PM
Gears of War 2. Gra Idle Banter 23 12-07-08 03:11 PM
Shift-I Shift Light phizog SV Talk, Tuning & Tweaking 11 09-07-08 12:18 AM
