Old 01-10-07, 02:00 PM   #11
Spanner Man
Default Re: Correct order of doing the following jobs
Afternoon all.
You need to get your balance sorted, as it sounds as if it's way out.
Unfortunately there are no tell tale signs that the clearances need doing until it's too late, so you'll just have to get them checked.
On older five valve Yamahas such as FZ750's & Genesis/Exup 1000's a sure sign that the clearances needed doing was poor starting from cold. I have had a few SV's that have exhibited this behavior & plenty that haven't. So you can't even assume that just because it starts ok from cold despite running roughly, the clearances are ok.
Cheers.
P.S. Check your engine mounting bolts, if you're experiencing a lot of vibration.
Spanner Man
Old 01-10-07, 03:22 PM   #12
I do the TPS last, the throttle stop screw and cables are on the front TB, the TPS on the rear, as the TPS is set very near to a shut throttle and it's possible even with small changes in balance to alter the shut position of the other TB it can change the TPS setting - anyone who has adjusted the TPS will know how minute changes make a significant alteration in the TPS setting.
It may make no odds, there may be no significant change in balance required - but it always has the potential to.
Old 01-10-07, 04:37 PM   #13
Ceri JC
Thanks for the advice folks.
Old 01-10-07, 05:21 PM   #14
ClemsonSV
Don't forget the new cover sheet on your TPS report...
Old 01-10-07, 10:22 PM   #15
I'm_a_Newbie
Originally Posted by Spanner Man View Post
Morning all.
Valve shims first, TPS adjustment second, & balancing third.
No No No Balancing second, TPS third.
is it correct oil? viva_unix SV Talk, Tuning & Tweaking 10 23-12-07 05:41 PM
Is my licence correct??? neilhatch Bikes - Talk & Issues 4 25-03-07 09:08 PM
PSI gauges which one is correct ? SpankyHam Bikes - Talk & Issues 13 18-07-06 06:58 PM
The correct way to filter... caines Bikes - Talk & Issues 15 30-11-05 09:44 PM
