Old 02-10-07, 08:36 AM   #11
plowsie
Default Re: Strange Smoke From Bike
Two left triangular panels under seat first then you will see the screws to the seat to take it off.
Stu
Old 02-10-07, 08:38 AM   #12
hovis
remove the 2 black side pannels with allen key, then you can see the allen key bolts holding the seat on
then 2 bolts at top of tank, so the tank will lift, as there is a hinge at the bottom, you should have a long metal bar under the pilloin seat which will prop the tank up......... if not just use a bit of wood, or somthing
Old 02-10-07, 10:57 AM   #13
Biker Biggles
Biker Biggles's Avatar
Sure it wasnt the carbs spitting back on startup?That could blow some smoke back through the airbox which would come out from under the tank.
Old 02-10-07, 10:58 AM   #14
petevtwin650
You don't remove the black panels but hinge em back. Unless the plastic rivets at rear of panel have gone awol.
I don't reckon it's electrical. A fuse would have popped most likely or it would be continuing doing it. Possible spit back in carbs although not sure how the smoke is getting out (answered in Biggles post)
Old 02-10-07, 11:00 AM   #15
plowsie
Will find out in an hour if we happen again, LUNCHTIME !!!!
Old 02-10-07, 11:00 AM   #16
hovis
wow.......... you still have the plastic rivets?
well, i was guessing he did not still have them, as i did not think he would
2 berth caravan (i know strange on a bike forum) ricky Idle Banter 1 30-07-08 07:09 PM
Strange noise from bike ricky Bikes - Talk & Issues 6 22-05-08 10:09 PM
Hello from the Big Smoke! Jester666 Thames Valley 37 17-08-07 11:42 AM
bike wont start very strange??? sv650ninjaman SV Talk, Tuning & Tweaking 8 06-07-07 05:49 PM
Another strange question...bike won't reverse Freeloader SV Talk, Tuning & Tweaking 6 23-01-06 08:00 PM
