Old 31-12-20, 03:51 PM   #1991
DJ123
DJ123's Avatar
Default Re: What have you tinkered with today?
New tyres on the bike today, the Michelin Road 5's. Just need a dry day to go and bed them in. And the weather forecast looks like that'll be in a couple of weeks.
BMW F800ST
Old 04-01-21, 09:12 AM   #1992
DamoK4
I’m due some new tyres, was thinking of trying the pilot 4’s. I’ve got pirelli diablo’s on at the moment but there’s a nice flat in the middle of the rear and they are 4 years old. Not sure when the previous owner had them fitted
DamoK4 is offline   Reply With Quote
Old 04-01-21, 11:36 AM   #1993
Adam Ef
Adam Ef's Avatar
Got all the bits together to overhaul the forks on the VFR so went out to the garage and .... looked at all the parts .. and came back inside. It's too bl£$%y cold!
Past:
Old 04-01-21, 12:47 PM   #1994
DJ123
DJ123's Avatar
I'd say go for the Road 5's, if the jump in price is not too much.
BMW F800ST
Old 04-01-21, 03:46 PM   #1995
Adam Ef
Adam Ef's Avatar
+1 for the road 5. I had the PR4 and they were good, but the road 5 have been quite a lot better.
Past:
Old 04-01-21, 06:17 PM   #1996
Adam Ef
Adam Ef's Avatar
Actually braved an oil and filter change in the end. The VFR does get nice and warm to work next to once warmed to thin the oil.
Previous owner had said he did have it serviced... and then admitted it was just an oil change. Judging by the milky look of the oil that was a few years ago too. The bike sounds much happier already with the new oil in.
Past:
Old 13-01-21, 08:09 PM   #1997
gt900uk
Junior Member
New rectifier fitted after I broke down the other day. Got a sparkbright eclipse coming so I can keep an eye on the charging system so will get that fitted too.
Had bought a new battery from an nearby halfords that got me home on the day of the breakdown.
gt900uk is offline   Reply With Quote
Old 16-01-21, 07:38 PM   #1998
aj76
Tested my new took kit today, full service on the scenic, including diesel filter and pollen filter. Looks like thermostat housing gasket is starting to fail and bloody automatic brake sensor broke off clutch pedal. Fingers crossed a bit of super glue will sort it otherwise it's a real pain in the ar$e
Sent from my Pixel 5 using Tapatalk
aj76 is offline   Reply With Quote
Old 16-01-21, 07:53 PM   #1999
Adam Ef
Adam Ef's Avatar
Swapped out tyres on the DRZ. Pinched the rear tube, so it has to come off again. Also found out the rear bearings are totally seized, so need be ordered too. Still not sorted the wrong length throttle cables issue. I've refitted the old ones, which stick really badly. Then it got dark again... looking forward to longer daylight days to work in.
Past:
Old 18-01-21, 07:15 PM   #2000
Adam Ef
Adam Ef's Avatar
Checked valve clearances on the DRZ. A lot quicker and simpler working on a single cyclinder engine than the ZX6R inline 4 was! One exhaust is valve is maybe 0.01mm out of spec, so I;ll live with it until I've got everything else checked and working. Still not throttle cables. Ongoing dispute with seler. Has now agreed to accept them back and check lengths. Also checked the spark plug... once I'd managed to clear the farm yard out of the recess so I could get the tool in there to remove it. It was really packed with mud and hay and involved making an angled pick from a bicycle spoke and a right angled micro aluminium straw attachment for the hose on our vacuum to clear it out. Dremels and gaffa tape to the rescue to make the straw. The more I do on this bike the more it shows up that more needs doing. Need to get the swingarm off next to check and see if the bearings are as bad as the back wheel is.
Past:
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
