Old 28-09-10, 06:58 PM   #2391
kellyjo
Default Re: 'Ere 'ere is the EAR Megathread
aah, you would be lost without us...
Old 28-09-10, 07:18 PM   #2392
Rob969
Has anyone tried any of the bolt kits on their bike seen a lot of aluminium bolt kits but i'm a bit concerned that they wouldn't really be strong enough is it worthwhile spending more on stainless ones especially on the engine bolts. Think alloy ones would be ok for the fairing and screen. Figure if i'm going to strip the bike right back and tidy it up i might as well do it properly
Old 28-09-10, 08:39 PM   #2393
Mike2165
Originally Posted by Skip View Post
What did I do to deserve you lot!
Turned up
Old 28-09-10, 09:31 PM   #2394
speedplay
Originally Posted by Mike2165 View Post
Turned up
**** me, I thought you had died and gone to hairdresser heaven....
Old 28-09-10, 10:24 PM   #2395
svrich
Rob,
I fitted a pair of GSXR mirrorcators after I failed to find a good set of originals after my off last year. There was a lot of measuring done to get the angles right, and a lot of head scratching, but I like the end result. The mirror position is better than original and I like that the indicators are higher and bigger. Apart from the endless measuring all I had to do was make up a bracket for each side so that they were secured to the subframe. It was a fiddly job but fairly easy. The original mounting holes were cut flush on the inside of the fairing (they were both cracked anyway) and the fibreglassed and filled before a complete respray. If you're interested in having a go I'll take some better pictures. These two aren't great but if you look closely at the avatar you can see the complete picture.
I'm planning on using some off cuts of the old fairing to blank the old mirror holes off, one day .
Old 29-09-10, 07:36 AM   #2396
Skip
Skip's Avatar
I can highly recommend Chewys Stuff for this - my curvy had a full bike kit on and not only do they look better than the standard cheesium bolts but you know they are not going to round off when you try to undo them.
Well worth the money.
http://www.chewys-stuff.co.uk/
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 29-09-10, 08:08 AM   #2397
BigBaddad
KJ has a bolt on...or is that a strap on? Skip?
Old 29-09-10, 08:26 AM   #2398
kaivalagi
Makes me wonder what KJ would have done to break me in...
Old 29-09-10, 08:29 AM   #2399
Reeder
Old 29-09-10, 08:34 AM   #2400
kaivalagi
http://scienceblogs.com/deepseanews/...going_wher.php
Leatherback Turtle dives 1000m deep!............
Madlanders Megathread derbybiker The Madlanders 307 18-09-22 09:47 PM
megathread Frank Idle Banter 10 22-01-08 07:41 PM
GM megathread Mark_h Guildford Massive 5 25-05-07 10:30 AM
