Old 15-11-21, 07:57 PM   #2511
Adam Ef
Adam Ef's Avatar
Default Re: What have you tinkered with today?
Originally Posted by svenrico View Post
IHow do you leave Abba kit in place anyway, the brass fittings would just drop out ?!
Use the swingarm kit which bolts in place of one of each of the footpeg bolts and can stay there.
Past:
Old 15-11-21, 11:24 PM   #2512
svenrico
svenrico's Avatar
Thanks ,wasn't aware of that, my Abba kit fittings push into the swingarm pivot holes. Will look into that for my 2020 SV650A.
svenrico is offline   Reply With Quote
Old 15-11-21, 11:26 PM   #2513
svenrico
svenrico's Avatar
Originally Posted by DJ123 View Post
Adam mentioned the swingarm kit, so would be (i assume) Bobbins/cotton reels you leave in. Not the frame lifters.
Apparently some Abba fittings can be fixed to rear footpeg brackets rather than into swingarm pivot points like I have.
ps sorry, obviously the front not rear footrest brackets.
Old 15-11-21, 11:50 PM   #2514
svenrico
svenrico's Avatar
Have obviously been here before but forgotten the reply below that I received previously from Abba.
In most cases we would recommend that the SARK is fitted to the frame lug
itself & not the outside of the hanger (although this is possible in some
cases) obviously if the hanger is removed they cannot be left this way.
The SARK fittings also stick out so may hinder foot movement when riding.
For routine use we would always recommend using the swing-arm adapter kit on
the bike & not the swing-arm removal kit. The swing-arm removal kit is
primarily for just that job - removing the swing-arm.
Those are our recommendations, obviously your are free to follow them or not
at your own discretion/risk.
Hope this helps.
Best regards
abba Motorcycle Equipment UK Ltd
29 Cutlers Road
South Woodham Ferrers
Essex
CM3 5WA
Tel: 01245 322331 (Sales: Option 1) (Technical: Option 2)
Email: info@abbastands.co.uk
Web: www.abbastands.co.uk
Old 15-11-21, 11:54 PM   #2515
svenrico
svenrico's Avatar
Please see my previous correspondence with Abba which I had obviously forgotten. Do you leave the fittings fixed to the footrest brackets or remove the footpeg brackets and fix to the frame lugs as Abba suggest. Forgive me if we have been through this before.
ps sorry, they obviously have to fix to the front footrest hanger if the Abba fittings stay in place.
Old 16-11-21, 05:22 PM   #2516
Adam Ef
Adam Ef's Avatar
I left mine permanently in place of one of the footpeg bolts with the footpegs on. I didn't find they got in the way at all.
Past:
Old 16-11-21, 06:16 PM   #2517
yokohama
I did the same as Adam on my SV. Removed one of the footpeg bolts, replaced it with a swingarm removal kit fitting and just left it in. They are not very big and didn't bother me at all.
Old 16-11-21, 06:42 PM   #2518
svenrico
svenrico's Avatar
Yes, thanks. I think we might have had this conversation before ( I am still on a Honda cb650 forum from when I had my last bike and I think I sometimes get mixed up about which forum I have commented on , or that's my excuse anyway, but more likely just old age !!!)
Anyway I am going to order the ABBA swingarm removal kit, it sounds more like a handy way of raising the rear end for a quick clean of the wheel rims or whatever. I could still use the swingarm pivot points fittings when the bike is laid up in the garage for a longer period in winter.
Old 16-11-21, 08:56 PM   #2519
yokohama
It might be worth waiting until black Friday. There's a chance of a discount with maybe free delivery.
Old 17-11-21, 08:19 PM   #2520
svenrico
svenrico's Avatar
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
