Old 29-11-21, 05:57 PM   #2541
SV650rules
Default Re: What have you tinkered with today?
a long time ago i used to have mud and snow tyres on the car and caravan but you were restricted to 70mph or something like that. they were great for getting out muddy fields.
Modern M&S tyres don't have the huge tread pattern like something the army would use ( all terrain tyres ) - they are no noisier than summer tyres. AFAIK speed ratings for modern winter tyres are pretty much the same as summers.
2016 SV650 AL7
Old 01-12-21, 06:12 PM   #2542
Adam Ef
Adam Ef's Avatar
Hooked up the auxialliary lights on the DRZ. Bit of a faff running all wiring and soldering in from a switched live to the relay, then trying to fit it all tucked away in limited space. Got a feeling they're going to be too bright though and they have a flashing setting I wasn't aware of every third time they're turned on. Bit odd and not something I wanted, but they're fitted now.
Past:
Old 01-12-21, 06:47 PM   #2543
garynortheast
garynortheast's Avatar
Sounds like it could be entertaining Adam, careering down wet muddy lanes in the dark with a strobe light by which to see your way!
Blue Curvy S with over 110,000 miles and still going strong.
Old 01-12-21, 07:55 PM   #2544
Adam Ef
Adam Ef's Avatar
Yep. Next job is to fit the soundsystem so I can blare out hectic techno to go with the lighting
Past:
Old 01-12-21, 08:02 PM   #2545
garynortheast
Old 09-12-21, 07:59 PM   #2546
DJ123
DJ123's Avatar
Fitted a ground anchor today. Got a good deal on a squires one & decent chain lock for the bike in the Garage.
BMW F800ST
Old 10-12-21, 08:19 PM   #2547
Craig380
Did a brake fluid flush on my Gen 3. Despite being nearly three years old, the old fluid still tested OK for moisture content, but it's a good job to do while the bike's not in regular use.
Old 11-12-21, 03:39 PM   #2548
Adam Ef
Adam Ef's Avatar
Struggling with a stuck link pipe. Once it's off I'll be struggling with a stuck lambda sensor.
Past:
Old 11-12-21, 05:13 PM   #2549
DJ123
DJ123's Avatar
i change mine on the Bike & car every 2 years. And generally when i replace the pads (& discs) too.
For the low cost/low effort its well worth it for the improvement in braking performance and feel.
BMW F800ST
Old 11-12-21, 05:14 PM   #2550
DJ123
DJ123's Avatar
I installed a tie down point onto the trailer. A nice solid anchor point to lock the bike onto, as well as locking the trailer to the car (when being left).
BMW F800ST
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
