Old 10-04-22, 10:00 PM   #2641
EssEllTwo
Default Re: What have you tinkered with today?
Originally Posted by svenrico View Post
Ah well, if it has had 2 previous owners who knows what they might have done !
ps having said that, at that mileage it will still be under warranty won't it ,how old is the bike ?
It's 7 years old now so I'm sure the warranty is long gone. As I've got a new shock arriving next week anyhow, I'm not too bothered but it is a bit ****.
EssEllTwo is offline   Reply With Quote
Old 11-04-22, 12:04 PM   #2642
svenrico
svenrico's Avatar
Originally Posted by admin View Post
I didn't realise paraffin was water soluble. I was expecting it to leave an oily residue but if seems to wash off quite easily with soapy water.
My usual cleaning routine on the motorcycle was to clean with white spirit to get rid of the worse of the mess in the chain area and then use a degreaser to remove any remaining dirt. Looks like I'll be using your approach in future
Paraffin isn't water soluble is it ?!
I use paraffin to clean the chain but the owners handbook says don't use kerosene. What is kerosene - I thought it was what the Americans called paraffin? !
I cleaned the chain a few weeks ago and rubbed gear oil on it ( I also have a Scottoiler fitted ) but it seemed gungy so I cleaned it again and rubbed Scottoiler blue oil over it .Haven't ridden it since though as I am waiting for a new shock absorber.
Scottoiler oil has some tacky anti fling properties that gear oil doesn't have.
svenrico is offline   Reply With Quote
Old 11-04-22, 12:26 PM   #2643
Grant66
Grant66's Avatar
Wouldn't have thought so, but it does mix fairly well. Agitate the bottle before use.
The watering down is just to take the strength down and to wash the loosened crud away.
Sent from an S20 using Tapatalk with that kin cr4p blocked
Formerly known as Gajjii
Previous Bikes: Red Sk1 Curvy, Red MT-07.
Current Bike: Black MT-09.
Grant66 is offline   Reply With Quote
Old 11-04-22, 01:42 PM   #2644
https://en.wikipedia.org/wiki/Kerosene
so whats it called in the UK?
Old 11-04-22, 04:39 PM   #2645
Seeker
Seeker's Avatar
We use the words interchangeably but paraffin is slightly more refined than kerosene. Paraffin has been changed to emit fewer odours.
https://www.nationwidefuels.co.uk/oi...sene-paraffin/
There's a nice table in this link that highlights the differences:
https://www.differencebetween.com/di...-and-kerosene/
2016 SV650AL7
2023 GSX-8S
Old 11-04-22, 06:40 PM   #2646
svenrico
svenrico's Avatar
So I suppose the question still is- 'is paraffin safe to use on O ring motorcycle chains?'
Old 11-04-22, 08:06 PM   #2647
daktulos
daktulos's Avatar
I thought it was what the manufacturers always recommended using.
daktulos is offline   Reply With Quote
Old 11-04-22, 08:16 PM   #2648
daktulos
daktulos's Avatar
Which handbook? The Curvy one says the opposite:
Old 11-04-22, 08:34 PM   #2649
Seeker
Seeker's Avatar
I hope so, I've been using it for years.
2016 SV650AL7
2023 GSX-8S
Old 11-04-22, 09:19 PM   #2650
yes and the workshop manual states that you should use brake fluid to install calliper seals which we all know is wrong.
the reason we are not to use paraffin and things to clean o'ring chains is that it can "wick" behind the o'rings and destroy the grease. grease removal is the number one cause of chain stretch and seized links. technically you should not use a scotoiler either as the oil does the same but in practise a scotoiler is better. btw chain plates dont stretch its the rollers that wear and the grease dissipates.
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
