#2661 | |
Well the pin and side plate still take the force even on a riveted chain, all the split link clip is there for is to stop the pins working their way sideways out of the chain... When you get a DID chain ( IIRC ) they supply a split link and a link for riveting - I will probably use split link next time - but you have to fit clip so that open end is the trailing end.
#2662 | |
#2663 |
Went to my friends workshop and used his machine to change the front tyres on my Zafira. Makes the job nice and easy, rather than struggling with oversized tyre levers.
https://teulu.bandcamp.com/releases Blue Curvy S with over 110,000 miles and still going strong. ![]() |
#2664 |
#2665 |
He has a balance machine too, but I don't normally bother. The wheel is balanced and tyre manufacture is pretty accurate these days, especially with the major brands.
#2666 |
Fitted a dual USB socket in place of the standard charging port. Should be more waterproof/secure in holding the cable to charge when plugged in.
#2667 |
Quick once over yesterday to check oil level, Scottoiler level, tyre pressures, and chain tension, ready for Friday's ride out.
#2668 |
Bought a 12v pump off amazon last week, successfully used it this morning to do an oil change on my van, sucking oil out via the dipstick is infinitely easier, sod crawling around underneath to take sump plugs out!
#2669 |
Services the Suffolk punch mower, replaced broken drive gear and some springs getting ready to have a nice lawn hopefully this year
![]() Sent from my Pixel 5 using Tapatalk |
#2670 |
New rear tyre on the bike today. And had a good ride out to scrub it in too.
