Old 26-01-09, 10:40 PM   #261
Dave20046
Dave20046's Avatar
Default Re: Bent Banana - The SV resurrection.
Crankcase vent pipes to the airbox.
That two ones on the left? Where do they enter the case? Is it accessible with the box and tank on?
Old 26-01-09, 10:46 PM   #262
Yeah it's easy if you have tiny hands. So generally a total pain in the rse.
Front one goes to front camchain tunnel area at the bottom end of cylinder head. Rear one goes to near the gearbox.
Old 26-01-09, 11:06 PM   #263
Northy are you losing your touch? Clutch cover is on the RHS.
Clutch pushrod cover, I meant. Front sprocket cover.
Old 26-01-09, 11:23 PM   #264
Old 27-01-09, 07:08 AM   #265
Dave20046
Dave20046's Avatar
I knew what you meant northy
Old 27-01-09, 07:26 PM   #266
Dave20046
Dave20046's Avatar
man we are leaking in a lot of places ...hopefullly repairable places. Will report back later, im off to drown my sorrows
Old 28-01-09, 09:37 AM   #267
Dave20046
Dave20046's Avatar
Soo from what I can see, slight leaking round the timing windows plug thing at the top (probably just wants a new copper crush washer), just below that there is the 10mm allan key plug that I've faffed around with on the left hand side of the engine casing - I don't think I seated it right as it's leaking at the bottom. The rear of this casing (not too acessible) also seemed a bit moist and a drip appeared at the bottom of the clutch adjustment doo da.
The oil drop sump thingy is also dripping (hopefully just a new washer again) and the clutch case cover is leaking.
My radiator is also leaky (suprise) but I'm gonna radweld the **** outta it.
Old 28-01-09, 09:39 AM   #268
Dave20046
Dave20046's Avatar
I've got some pics of my talc'd bits to follow if anyone cares
Old 28-01-09, 07:56 PM   #269
Dave20046
Dave20046's Avatar
Attachment 3089
Attachment 3090
That's just after I'd degreased and talc'd - and I'll post some of today ( a day later)
Old 28-01-09, 08:57 PM   #270
That which is dripping off the sump plug is likely to be just the leaks everywhere else running down.
Bent rim! phil24_7 Bikes - Talk & Issues 18 01-11-07 02:51 PM
The worlds straightest banana gazman Photos 15 19-08-07 07:21 PM
Geostationary banana over texas philipMac Idle Banter 5 01-02-07 10:21 AM
2000 W reg naked tweaked banana for sale Sloth For Sale - SV's and SV related items 0 25-06-06 12:28 AM
Photos of my new VFR Banana... chutz Photos 28 03-09-05 01:52 PM
