Old 08-01-11, 08:31 PM   #2691
speedplay
Default Re: 'Ere 'ere is the EAR Megathread
Originally Posted by Seggons View Post
That inspires confidence as I'll be doing a 5PM - till whenever shift tomorrow. I wish I was doing sky dishes, might be a bit more glamorous. I've been pulled off of doing the billboards in London to clean the bus shelters in Kings Lynn.
Was just wondering why we hadn't seen you about here mate.
Just remember, when doing the bus shelters, if it looks and smells like spunk, dont taste it to make sure..
Old 09-01-11, 09:44 AM   #2692
BigBaddad
I've been pulled off of doing the billboards in London.
When you're in King's Lynn you might get a BJ in a bus shelter
Old 09-01-11, 11:07 AM   #2693
Seggons
I've been very hard at work trying to please the boss on my 6 month probation period. Rideouts are looking a bit bleak for me this year since Sundays are classed as a working day for me.
As for spunk, that's something pleasant compared to some stuff in the shelters.
I hope they are ruddy quick, I'm only allocated something like 4 minutes per shelter.
Old 09-01-11, 08:16 PM   #2694
Rob969
Well this weekend i finally got round to getting my rear subframe repaired and gave it a respray fitted it back on the bike and a few bits to it. Fitted my fender extender although the mudguard is still of the bike plus i checked the valve clearances on the rear and found all of them are to tight never got round to checking the front hopefully they'll be with tolerance so i only need the rear shimmed. Also bought a slightly damaged set of lowers just need a bit of tlc and a respray plus a fitting kit which i need to get ordered from robinsons. And i've found out from another member that HEL will give me 25% discount for being in the armed forces so i'll be ordering a set of hoses from them soon
Old 09-01-11, 08:42 PM   #2695
kaivalagi
That's good to know, I might order some braided lines through a friend then
Are you getting 2 lines for the front or having the 3 line arrangement as Suzuki do by standard? As I never dealt with this sort of thing before I didn't know whether going with 2 lines rather than 3 (1 then 2) is okay to do? I assume both ends would fix onto the lever end next to each other if you used 2 lines? Anything else needed for 2 lines to work such as bolts etc?
edit: Just noticed brake-lines.co.uk have a 10% off for Jan too...
Old 09-01-11, 08:47 PM   #2696
Rob969
Probably go for the 2 line setup because its cheaper and its the RACE setup so must be way better lol
Old 09-01-11, 08:53 PM   #2697
kaivalagi
Yeah, just pricing up the front and back on the site now, might just buy it with the 10% off, saves all the messing about with the relatives up in Edinburgh...
There are too many colours though, black for a black bike or go with the clear and silver for the unmessed with look...?
Would the 2 line setup fit as is on the front do you think?
Old 09-01-11, 08:55 PM   #2698
To fit a RACE set up, you'll need a double banjo bolt at the mastercyclinder
Old 09-01-11, 08:56 PM   #2699
Rob969
Wouldn't you get that with the kit, think i may go for the stealth ones
Old 09-01-11, 08:56 PM   #2700
kaivalagi
Ah gotcha, I assume it's the better approach going with 2 lines? Better balance or makes no difference?
edit: m10 x 1.25 - one of these at £5 ish: http://www.merlinmotorsport.co.uk/p2...duct_info.html
Madlanders Megathread derbybiker The Madlanders 307 18-09-22 09:47 PM
megathread Frank Idle Banter 10 22-01-08 07:41 PM
GM megathread Mark_h Guildford Massive 5 25-05-07 10:30 AM
