Old 23-06-22, 10:33 AM   #2701
garynortheast
garynortheast's Avatar
Default Re: What have you tinkered with today?
Originally Posted by redtrummy View Post
How about shoe repair thread? I used kite string for one repair to leather, that was very strong but it was white!
Not sure but I suspect shoe repair thread may be a bit too thick.
Blue Curvy S with over 110,000 miles and still going strong.
Old 25-06-22, 03:07 PM   #2702
Cleared out the blocked fuel tank rainwater drain.
I had to do it last year too. It's the part that passes through the tank so not very easy to clean thoroughly.
Old 28-06-22, 11:17 AM   #2703
use the inner of an old clutch cable the one with the ball end and not the barrel.
Old 28-06-22, 04:27 PM   #2704
I knew you'd be the man with the answer. Wealth of experience
Old 29-08-22, 03:23 PM   #2705
garynortheast
Changed the front tyre. Don't know why but it was a bit of a pig of a job this time. I normally have no trouble removing and replacing tyres. Just a bit out of practise I guess as I haven't changed one for a while.
Old 30-08-22, 11:05 AM   #2706
svenrico
svenrico's Avatar
Originally Posted by daktulos View Post
I need to do that, too - what sort of thread do you use?
Cox leather repair shop (now gone sadly) sold me a special needle and thread a few years ago for mending leather. Think the thread might be waxed.
svenrico is offline   Reply With Quote
Old 30-08-22, 11:07 AM   #2707
svenrico
svenrico's Avatar
Thanks chaps - Curvy or pointy? always confused me, it has no fairing and is the naked variant . Now it just stops, no splutter, just dies both cylinders together. I put the old plug in without disconnecting any wiring, could I have strained a wire? I was very careful. Looking inside the tank no real sign of rust. It lives in a garage and never gets wet (apart from its annual clean, if I can help it) It has got worse so will check plug cap, but it does not appear to go onto one cylinder, just dies and will restart after and will run for 800yrds or so. Battery is less than a year old, holds its charge and restarts the bike ok. I have confidence in the battery it spins the bike well.
Has this been resolved ?
Old 30-08-22, 12:14 PM   #2708
redtrummy
Hi Svenrico
I am pretty sure I posted athe fix but I may have forgotten to hit the Post button.
Answer Yes! I had changed the front plug by twisting the rad sideways a bit for access, that's when the problem started. Fortunately as I wandered round the bike trying to decide where to kick it first (ala Faulty Towers) I noticed that the water coolant was low - topped that up now all ok I had changed the antifreeze a couple of years before!. The temperature overload switch must have activating. I did not lose any fluid when I changed the plug so I must have had an airlock which I released moving the rad about.
Really annoys me when problems are resolved but solutions not shared
redtrummy is offline   Reply With Quote
Old 31-08-22, 06:16 PM   #2709
garynortheast
First ride after fitting the new front tyre. I'd forgotten how much better the SV handles with a new tyre instead of the worn out one!
Old 23-09-22, 04:38 PM   #2710
Stilo
Stilo's Avatar
Took the engine out of a 2013 Gladius that I bought in need of serious TLC. The previous owner said "it made a noise and lost all power" he then drained the oil which "had bits of metal in it". I'm assuming the engine is fubared but Im going take the barrels off and have a look anyway. Does anybody know if the very latest V Strom engine will fit?
He was a hairy handed Gent who ran amok in Kent Awhooo
Stilo is offline   Reply With Quote
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
