Old 29-01-09, 06:00 PM   #271
Dave20046
Dave20046's Avatar
Default Re: Bent Banana - The SV resurrection.
worrying!
Anyway here's a couple of pics from a day later.
Attachment 3095
Attachment 3096
Any tips on sorting the clutch cover anyone? I'm going to attempt it in 5 minutes. I'm guessing the course of action should be, undo all the bolts round the edges, pull off, clean oil off, apply hermadite (or whatever its called), plonk back on and torque? up.
Old 29-01-09, 06:01 PM   #272
Dangerous Dave
Is it cracked or warped?
Old 29-01-09, 06:25 PM   #273
Dave20046
Dave20046's Avatar
Neither, that I'm aware of. Can you tell from the pic? It won't have got hit in the accident.
Old 29-01-09, 06:29 PM   #274
Dangerous Dave
Remove it, clean it and place it on a level surface to see if its warped or not.
When you go to refit it be careful not to overtighten the bolts, this is a common cause of oil leaks, they should only be tightend to 10Nm. Most of mine is held together with silicone sealent, it has a slight warp.
Clean that side of the engine with degreaser, run the engine and look for any signs of a leak.
Old 29-01-09, 06:30 PM   #275
Dave20046
Dave20046's Avatar
cheers, will let you know how I get on
Old 29-01-09, 06:31 PM   #276
have you been overtightening or even undertightening those bolts on the clutch casing, Looks like mine actually, but mines been leaking for months, just need chris to put some silicone sealant on mine to hopefully remedy it.
The alternator plug? have you had that one out? i had a crack in the plug after a certain person that lives indoors put an impact driver through it, and put a hairline in it. i didn't realise it was leaking, thus starving my front cylinder of oil and having to replace the cylinder head.....grrrrrr.
edit, like Dave says the clutch bolts are a common problem,
Old 29-01-09, 06:46 PM   #277
There doesn't seem to be anything at all there that a bit of sealant will not sort.
Old 30-01-09, 08:12 AM   #278
Dave20046
Dave20046's Avatar
I overtightened them a coupleo f days ago before talcing to see if it would remedy the leaking (smart move I know ). The clutch case cover looks completely flat, if it's warped at all it's minimal. The alternator plug I had removed (was scared to death I'd cross threaded it as it didn't look flush) but I've took it out and it looks okay, so does the rubber seal. Think I'll just red hermatite the clutch cover if it's suitable? And can I do the same on the alternator plug? I'm going to either replace or re expand the copper crush washers on the top timing plug thing and the oil drain bolt.
The oil was extremely black (when in a mass in the tub) to say it had only done 6 minutes tick over and revving on it Unless maybe I hadn't completely drained the oil properly last time.
Old 30-01-09, 08:13 AM   #279
Dave20046
Dave20046's Avatar
I'd like to hope so Hardy bikers is looking a bit more of a reality now Hope it warms up a bit in time though we are gonna get snow and temps about -7 next week. Anyhoo don't let me forget gaffa tape on the ride out.
Old 30-01-09, 08:16 AM   #280
Dangerous Dave
Any decent silicone sealant will do the job.
Bent rim! phil24_7 Bikes - Talk & Issues 18 01-11-07 02:51 PM
The worlds straightest banana gazman Photos 15 19-08-07 07:21 PM
Geostationary banana over texas philipMac Idle Banter 5 01-02-07 10:21 AM
2000 W reg naked tweaked banana for sale Sloth For Sale - SV's and SV related items 0 25-06-06 12:28 AM
Photos of my new VFR Banana... chutz Photos 28 03-09-05 01:52 PM
