#21 |
you can also get ones that play music while you brush....
#22 |
The sonic ones really are worth the extra over the standard rotating brushes, I've had both in the past and the former gives a much more polished feel to your teeth.
The UV cleaner / bluetooth / timers are just gimmics though IMO, if you can't rinse off your brush or guesstimate 2 minutes, you're probably best not putting anything in your mouth in case you choke yourself ![]() |
#23 |
Oral B triumph - with flossaction heads. Not as good as flossing but quite good at cleaning inbetween. £0 sec timer helps move the brush along. Also tells you when to change the heads. Good charge and will last more than a few days.
"an unedifying exercise in postmodern, operatic grunge" Was - 2000 Candy blue sv650s -2003 Sonic silver sv1000s Gone - 2007 Wildfire Orange Ninja zx6r Now - 2010 Triton blue sv650s -Back to the future |
