#21 |
would a gsxr 600 or 750 front end swap be the best option? then you would also get the better brakes of the gsxr. or does different lenght of fork , geometry etc upset the bike.
#22 | |
#23 |
If you get the emulators you'll still need stiffer springs and I strongly recommend preload adjuster caps if you don't already have them. I think Traxxion also sell the emulators at a vastly inflated price, and grind on something about replacement damper rods with all the brazing done. God knows what they're on about, the emulators they supply are the Racetech ones (get them from PDQ) and apart from drilling a couple of holes, fitting is easy.
#24 |
what's actually involved in a spring and fork oil change?
are we talking front wheel off, forks off, then disassemble each fork, replace the spring and oil and then reassemble?? are there any major problems a novice could encounter? for example how hard is it to compress the new spring into place (my dad has told me the story of a work mate who was changing a car spring back in the 80's and as he was compressing the new spring it sprang back and punctured his abdomen!!! ![]() it's something I'd like to do this year as at 13st the front is still too soft even fully screwed down. and for £55 plus oil it's a tempting.... Cloggsy, are you attempting this yourself? |
#25 | |
The only thing I'd say is that you can make things alot easier by doing things in a certain order. For example, loosening (but not taking off) the fork caps while they are still on the bike. edit: Other things to think about are, even with stiffer springs you'll probably want to cut spacers to increase the preload. You'll need to know how to set preload as well. In fact, if you can get someone whos done it before to help you, I would. |
#26 |
I thought it could be done in-situ, no?
#27 | |
#28 | |
#29 |
![]() ![]() it's probably a better idea for me to lose some weight instead of destroying the front end of my bike!!!! |
#30 | |
rear shock nut and bolt for a diff shock | drag | Stuff Wanted | 0 | 22-04-08 03:52 PM |
Gen 1 w/zx6 shock, 05 GSXR forks, notes & question | JuicyGuzzi | SV Talk, Tuning & Tweaking | 14 | 10-10-07 09:43 PM |
been all through search, but still need shock info | P1PRX | SV Talk, Tuning & Tweaking | 6 | 15-02-07 04:29 PM |
Maxton Fork Conversion | tonyt | SV Talk, Tuning & Tweaking | 9 | 02-06-06 08:27 PM |
Will K3 Maxton Springs fit a K1? | The Wolf | SV Talk, Tuning & Tweaking | 3 | 17-06-05 02:31 PM |
