#21 |
Good call but no. When I put the bike away I distinctly remember leaving the parking lights on and then going back to turn them off again.
"Bah" - ASM Forever, RIP. 13/03/1986 - 05/04/2008 "I'm so crazy" - Lulu West, RIP, 16/04/1995 - 16/07/2009 CBR600RR7 Link to map of TV members...if your not on the map then PM me. My facebook profile |
#22 |
Most likely its been sat around for the three months it was in for repair. It was probably not trickle charged and the alarm has probably slowly munched the battery. Thats my best guess.
#23 |
I think you are probably right. Once quick question though. If the battery charges up again should I still go through the hassle of trying to get it replaced under warrenty?
#24 |
Had very similar problem to K3 Gixer. Left standing for a couple of weeks and that was that. tried charger with recover facility etc ok for a couple of runs then dead again. Been on recovery charger for well over week but dead as dead can be. Result - new battery!
#25 |
Bike batteries are quite small and exposed to the elements compared to a car battery - the first sign of cold weather can often cause havoc, and it was cold last night, so I guess that's what did it. Try charging it before chucking it out, you might be lucky, although the chances are that if it's died once, then it will go again
#26 | |
However if you slip the bike on a trickle charger when you come in, it should still be fine to use. I had a knackered battery that i used for 6 months...it just needs more care to keep it going. As its under warranty, i reckon it must be worth trying to get a new one. Worst case scenario you take it in and they tell you its ok to use. Have you been charging it in the evenings...as with all the reduced visibility/light, you're probably riding with lights on all the time. Before you decide the battery is knackered, give it a good charge and give it a chance. |
#27 |
#28 | |
Flat battery? | appollo1 | SV Talk, Tuning & Tweaking | 8 | 19-05-08 06:05 PM |
Flat battery | cuffy | SV Talk, Tuning & Tweaking | 8 | 15-04-06 12:27 PM |
flat battery-again! | ronshaw | SV Talk, Tuning & Tweaking | 4 | 02-08-05 08:04 AM |
FLAT BATTERY!! | philb | SV Talk, Tuning & Tweaking | 5 | 19-05-05 10:42 AM |
Flat battery | leatherpatches | Bikes - Talk & Issues | 12 | 12-05-05 09:47 PM |
